bassaddiction Posted September 29, 2013 Report Posted September 29, 2013 i recone this hdc3 1 month ago i just started hearing a noise from it. my first thought was dam blew another one fuck. i took the sub out and saw this. the spiders separated and the ring was slapping around making that noise wtf. the spider i ca guled, is still attach to the sub ??????? im going to call aq tomorrow, just wanted to know what u guys think. only on aq 2200 at 4 ohms
Nikitaaa Posted September 29, 2013 Report Posted September 29, 2013 Did you do the recone your self? 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
tacomaguy1 Posted September 29, 2013 Report Posted September 29, 2013 The plastic ring came Unglued from the basket? Team Flex Issues
bassaddiction Posted September 29, 2013 Author Report Posted September 29, 2013 this was my first recone i did. the plastic rig is still connected to top spider there's 3 i think
n8ball2013 Posted September 29, 2013 Report Posted September 29, 2013 But not connected to the basket right? Id just glue it backdown THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
bassaddiction Posted September 29, 2013 Author Report Posted September 29, 2013 ya i fingered that. have no more ca gule anywhere local i can get that stuff btw the hole top spider came off other two are good
Nikitaaa Posted September 29, 2013 Report Posted September 29, 2013 ya i fingered that. have no more ca gule anywhere local i can get that stuff btw the hole top spider came off other two are good I would see if you can take of the dustcap and remove the spider. That way, you can easily clean the shit out on the gap and you won't be putting glue over glue. 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
bassaddiction Posted September 29, 2013 Author Report Posted September 29, 2013 ya i fingered that. have no more ca gule anywhere local i can get that stuff btw the hole top spider came off other two are good I would see if you can take of the dustcap and remove the spider.That way, you can easily clean the shit out on the gap and you won't be putting glue over glue. i was just going to vac out dust and lift it up put ca glue then clamp it. it didnt brake by dust cap and separate from cone if u mean that
ChevyBoy95 Posted September 29, 2013 Report Posted September 29, 2013 your error. spider pack game unglued from the landing. Pretty sure they use screws in the spider pack to hold it down along with ca glue, at least my hdc3 15s and hdc4s have them. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
Nikitaaa Posted September 29, 2013 Report Posted September 29, 2013 ya i fingered that. have no more ca gule anywhere local i can get that stuff btw the hole top spider came off other two are good I would see if you can take of the dustcap and remove the spider.That way, you can easily clean the shit out on the gap and you won't be putting glue over glue. i was just going to vac out dust and lift it up put ca glue then clamp it. it didnt brake by dust cap and separate from cone if u mean thatno, what I'm saying is you need a clean surface for the glue to work properly. If you try to just shove CA into the gap without bare metal your joint will fail instantly. Vacuuming out the dust won't help.My recommendation would be take of the dust cap, detach the rest of the spider, regrind the spider landing along with the spider surface and glue. Afterwards, shim the coil and when that dries reglue the dustcap and you're golden. Edit: forgot to mention you'll have to detach the surround as well. Edit #2:disregard this entire post, I assumed your spider came Unglued from the landing. 2007 M/T Honda Civic Coupe EX (4) Sundown Audio X-8's (2) Ampere Audio 3800.1's (3) Stinger SPV-44 Batteries (1) Mechman 240 3:1 Ratio 4th order sealed from the trunkTEAM NWSPLBest termlab scores to date in Honda trunk:151.7db legal (official) IASCA trunk 3 classBest termlab scores to date in my walled Subie:152.9db legal (unofficial) IASCA advanced 2 class155db outlaw
