XS Power
so i was thinking of getting a d7500 for about a 6000 watt rms system i have a d5100r up front and i was wondering if adding 2 more of those would be ok instead (due to the thread where you say more batteries would be better then a single) of the d7500 ill have a 180 amp ho alt or a 320 havent decided which one yet due too i might get belt slip on the 320 and that might be an issue
Edited by CstrokerV
Guessing you probably have Honda, so the odds are pretty high of you getting belt slip on a 320amp unless you do a lot of idler pulleys and get some good belt wrap.
The 7500 would be a lot stronger than two 5100R. The 7500 is going to give you the capacity of almost 3 D5100rs. Now if you were to compare 3 D5100Rs bussed together v/s 1 D7500, then the 3 D5100R would be stronger.
  • Who's Online   0 Members, 0 Anonymous, 1854 Guests (See full list)
