Possible without glassing?
So I have a stock 4x6 speaker location on my dash, and I want to put a 4" driver and a tweeter in there rather than a 4x6 coaxial. I have been looking for a speaker adaptor plate to fit this, but have found none for a 4x6 location at all. Is there a material I can use besides glassing a custom set? Thanks in advance!
Edit: I drive an 04 blazer
Vehicle: 2014 GMC Sierra 2500HD WT
Head Unit: Pioneer DEH-
Mids/Highs: Focal Integration ISC 165’s (front)
Subs/Amps: TBD
^this, just build your own out of wood but be sure to seal it up. The wood/mdf will rot when it gets wet. Fiberglass resin works well for this, but you could also use something like pladtidip or a water proof paint...
Team NorthWestSPL
The problem i the clearance. Even if I used 1/4 in MDF there wouldn't be enough room to mount the speaker and still have my dash on top, at least not with the excursion of the speaker. There woul be rubbing. I did the math and I would have about 1/16 of an inch between the surround of the speaker and the plastic dash. And the dash is one thing I donot want to cut.
Subs/Amps: TBD
Then use abs
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Then use abs
What's that?? Not tryna soun stupid, just unsure.
Subs/Amps: TBD
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
You could also reverse mount the speakers if you have the depth below the speakers.
Ah, I did not think of this. I am going to order some abs and see what needs to happen. Thanks for all the quick responses!
Subs/Amps: TBD
  • Who's Online   1 Member, 0 Anonymous, 3315 Guests (See full list)
