tburt915 Posted October 10, 2013 Report Posted October 10, 2013 will a d3400 be enough as my primary to run a sundown saz1500 and a rf 4 channel 300w amp? i have a stock 110a alternator and the big three upgrade.
Slinky Posted October 10, 2013 Report Posted October 10, 2013 will a d3400 be enough as my primary to run a sundown saz1500 and a rf 4 channel 300w amp? i have a stock 110a alternator and the big three upgrade. Yes DD M4 Rockford Fosgate P500-4 SoundQubed HDC415 w carbon fiber cap 2 Rockford Fosagate T1675-S XS Power D3400 Under Hood XS Power D5100 in rear Michael Singer 200A Alt Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
tburt915 Posted October 10, 2013 Author Report Posted October 10, 2013 so i should be fine without a batt in the back?
__d_a_v_i_d__ Posted October 10, 2013 Report Posted October 10, 2013 If you have the funds to add a battery(agm) in the back, I would do that . If not then you should be fine, just watch your voltage and charge your battery. Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
tburt915 Posted October 10, 2013 Author Report Posted October 10, 2013 right now i have a yellow top up front and a shriuken bt60 in the back and im typically sitting at 13.6v. i just heard somewhere that your alternator has a hard time charging two batterys and one big one under the hood is better.
Agreene Posted October 10, 2013 Report Posted October 10, 2013 test it, if it doesn't work (voltage drops past 12v on full load ) then add another battery in the trunk. simple
tburt915 Posted October 10, 2013 Author Report Posted October 10, 2013 What im debating is if i should sell my two current batterys and get one big one up front or if i should just keep what i have now?
