High Output alt from stock alt?
Are there any companies out there that will take a stock alt and remake it into a higher output? Im on a pretty limited budget, so Im just looking into options. Vehicle is a 99 Honda Civic with a D16Y8. Also, Im planning on runnng two SAZ-1500V3s, and a 4 channel, what would be the ideal alt and battery combo? Sorry for all the questions, just trying to get everything sorted out. Thanks in advance.
1999 Honda Civic- RIP
2003 Acura RSX Type-S
i would talk to Singer see what he can do for you
HU: Pioneer AVH x5800BHS SP Amp: AQ 120.4 Front SP: Hertz Hsk 165 Rear SP: DD cxs 6.5 SW Amp: Crescendo BC2000d SW 2 DC level 3 12" Electrical: Stock alt for now XS D2400 XS D3400 Knukonceptz Kolossus Second skin damplifier
On 8/8/2012 at 4:50 PM, Brandon15zzz said:
I heard he actually graduated college with a 4.0 gpa. Seems pretty gangster.
On 8/29/2012 at 12:25 AM, ILoveBass21 said:
he could blow a sub powering it with a potato.
Stock alts being upgraded is a tricky business. Most of the time you can only increase output a little bit, and depending on who does it, the alt may not be that durable.
Shop around for costs on all options. Most of the options I sell are in the 220A -$400-$550 range as an example
As for your electrical, to run 2) 1500W amps and a decent 4 channel around maybe 400W. You need to supply about 4800W.
So, a decent battery under the hood. maybe an XS Power D5100R. And a supplemental 2nd batter like an XS Power XP3000 will do ya nicely. Minus 1000W of juice for the engine and vehicle electronics, that leaves you with 5000W of supply to your audio system.
And that's 180 aH of battery. You should seek out an alternator of at least 180A and up from there.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Thank you both so much. @Maebros I'll be emailing Singer later today. @HHR, do you sell alternators in the 180 amp range?
For Hondas I only show 220A and up. But like I said, 180A is the minimum you should look at.
Ed Lester
ShowtimeSPL Host
My old Build Log
you can but only so much if its a 100amp alt they can probably get it to do 170 or so but your getting 2 1500 I would just get a 300amp alt or run dual alts
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
