Need help for box size for two Sundown zv4 12's (Updated)
ezkiiil
First starting with that I am from Norway (so don't hate me for the word and how I write a sentence) :)
I'm gonna build a box for two Sundown Zv-4 12.
How many liters does if NEED to be?
But if I am going to put two Zv-4 15's instead instead, how many liters does it have to be?
I have a VW golf 3, and for those who didn't know, it has a small trunk, but i want to have that sick bass.
Thanks for the help!
Edit: 19.October 2013
I've just made my own design for the box.. I don't know if it's good or not.. someone can come up with something?
So here's a picture:
The measurement inside the box are:
Depth: 350mm
Height: 420mm
Width: 875mm
The port is:
The left side of the port is "Depth" :184mm
Width: 144mm
Height/Lenght: 250mm
The box is (128,62Liters) - The port (6,62Liters)
128,62Liters-6,62= The box are at 122Liters!
Does it work for two Sundown Zv-4 12's? I want it around 32Hz, but I have no idea whats it is now... Smaller box?Biggerbox?Smaller port?Bigger port?
How big is your trunk first I see these things have a mounting depth of about 10in so at least need to have 15in(just my opinion) but I could be wrong hope some one ales with more sundown know page can help.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
12 zv.4 3-5ft^
15 zv.4 4.5-6ft^
I don't know sundowns recommended enclosure,but the 15zv4 wasn't happening in my 3.5 cube 30hz enclosure, did a single 15 at 5 cubes and I was very surprised how good it held up to a 2500bdcp.
Those 122 liters you say you have are good for two 12s but never for two 15s, likely you will need to setup a wall if you want the two 15s.
I'm going for 2 sundown zv4 12's
I got someone to design a box for me, it is tuned to 34.1Hz and the port is 50mm wide by 350mm tall by 690mm long..
I "re-designed" the port a little bit, just because I think it looks cooler. The port is now 300mm long by 270mm high by 150mm wide..
The T-port to the right, is at 12.075 liters and the on to the left that i've made is at 12,15.. does it going to work? will I get much windnoise? And how will the Hz be now?
  • Who's Online   0 Members, 0 Anonymous, 6077 Guests (See full list)
