Aero ports for a SQ SDC2.5 15 D4
BoomZoom808
Hey guys I want to do my first aero port box for a SDC2.5 15 D4 I just ordered. I am going to use the DD 15" compact Box plan but switch to Aero's to save some space and gain some efficiency hopefully. I am pretty sure this box will fit in my trunk.
24 wide X 19 Deep X 16.5 High
I plan on using the Aero ports below which come in 3" diameter by 6" long or 4" by 6"
http://www.rtboxes.com/accessories-aero-ports/
My question is should I used two 3" ports tuning to 35hz or a single 4" port tuned to 33hz? Thanks for any input you guys gave throw my way!
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Why are you trying to use 14 in2 of port?
I use that on my 10" and I get noticeable noise. Try that with a 15 around with close to the same xmax it will be much worse.
You also need to put in your driver displacement.
Krakin's Home Dipole Project
Thanks guys going to get a 6in aero instead. 9-12in per cu I hear is recommended for aero ports. Not really too concerned about the driver displacement was more concerned about chuffing
2010 Mazda 3s 2.5L
Knu OFC 1/0
A 4in port will be more efficient. How many rms you plan on using on that sub?
I am going to use my P1000X1D around 1k @ 2 ohms
2010 Mazda 3s 2.5L
Knu OFC 1/0
For port noise I would see if you can fit in a 8" port.
And if you can read through this. Flaring will help a whole lot.
http://www.subwoofer-builder.com/flares-25mm.htm
Its going to load off of the trunk so it shouldn't be that bad I am hoping. I am pretty sure I can get a 6in precision port locally but that is a good link for DIY ppl I don't have a router and don't really want to mess with it. I am hoping I will keep this setup for a while
2010 Mazda 3s 2.5L
Knu OFC 1/0
I wanted to bump this up for port/sub orientation suggestions. This box is going in a 05 Mazda 3 trunk.
I was thinking sub up port to the drivers side or sub back port to the drivers side. I don't have enough depth to do port back and sub back since the port is 18" long with the flares on and the box is only 19" deep.
2010 Mazda 3s 2.5L
Knu OFC 1/0
Thanks Joe X that's exactly what I did. I know it's definitely on the small side but it's within SQ's minimum requirements and I plan on giving it 1k. Going to mount the sub tomorrow and start breaking it in.
2010 Mazda 3s 2.5L
Knu OFC 1/0
  • Who's Online   1 Member, 0 Anonymous, 1450 Guests (See full list)
