Lyrix Posted October 20, 2013 Report Posted October 20, 2013 I own a set of Polk Audio db1222's which peak at 1500w and i recently bought a Pioneer GM-D8601 amp which peaks at 1600w, so i guess my question is; by overpowering my subs by 100w and i going to kill them? Or can i set the gain down to get less power and be good
truthsayer Posted October 20, 2013 Report Posted October 20, 2013 If you set your gains properly, you should be ok. Just make sure not sending a distorted signal. truthsayer
Jessica Posted October 20, 2013 Report Posted October 20, 2013 the amp is rated at 800 X 1 at 1ohm, the subs are rated 720 per pair. They are 2ohm subs, so you can wire to 1ohm and after rise and voltage drop you should be ok. An extra 30 watts per sub shouldnt hurt anything and its not likely you will see full rms on music anyway. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
pioneerforlife Posted October 20, 2013 Report Posted October 20, 2013 ^^ I second that Also for future reference you wanna look at the RMS (continuous) power instead of peak. peak is what the amp/subs can handle for around a second. RMS is what the amp can put out or subs can handle continuously. that's the best way to match subs and amps. 2007 Ford Focus SES Hatchback Pioneer HU 4 Digital Designs 9515i's in a B pillar. 2 Soundstream XXX 15K's (running at 16 volts) Soundstream Mids/Highs in custom door panels (getting rebuilt soon) Soundstream TA2.160 and TA2.400 Sky High and KNU wiring 3 Banks of Maxwell caps Winston Lithium (not a fan) Bump4Life 250 Amp Alt. aka USAlternators Soundstream Focus and Avenger Build Log Instagram @p4linnovation YouTube: Team Blowin Loud
SnowDrifter Posted October 20, 2013 Report Posted October 20, 2013 I like the sniff test. If you smell it burning turn it down lol ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Lyrix Posted October 20, 2013 Author Report Posted October 20, 2013 the amp is rated at 800 X 1 at 1ohm, the subs are rated 720 per pair. They are 2ohm subs, so you can wire to 1ohm and after rise and voltage drop you should be ok. An extra 30 watts per sub shouldnt hurt anything and its not likely you will see full rms on music anyway. alright, thanks man.
Lyrix Posted October 20, 2013 Author Report Posted October 20, 2013 I like the sniff test. If you smell it burning turn it down lol ill make sure i do this too LOL
Andreetje77 Posted October 20, 2013 Report Posted October 20, 2013 1 correction the subs in totall are 2 Ohms so the subs are 4 Ohm a piece, so the amp is playing @ 2Ohms 500 Watts. Sub; Electrical Total Frequency Response 27-200 Hz Nominal Impedance 2 ohms Efficiency 103 dB Amp; umber of Channels Mono Maximum Power Output 1,500 W Continuous Power Output (1 Ω, ≤ 1% THD+N) 800 W x 1 Continuous Power Output (2 Ω, ≤ 1% THD+N) 500 W x 1 Continuous Power Output (4 Ω, ≤ 1% THD+N) 300 W x 1
Jessica Posted October 20, 2013 Report Posted October 20, 2013 1 correction the subs in totall are 2 Ohms so the subs are 4 Ohm a piece, so the amp is playing @ 2Ohms 500 Watts. Sub; Electrical Total Frequency Response 27-200 Hz Nominal Impedance 2 ohms Efficiency 103 dB Amp; umber of Channels Mono Maximum Power Output 1,500 W Continuous Power Output (1 Ω, ≤ 1% THD+N) 800 W x 1 Continuous Power Output (2 Ω, ≤ 1% THD+N) 500 W x 1 Continuous Power Output (4 Ω, ≤ 1% THD+N) 300 W x 1 you might be right, bu sonic's specs states that its 2ohms per voice coil. edit: the owners manual only shows the "1212" model for the single sub version and it's 2ohm. Would stand to reason that the dual 12 model would be two 2ohm subs. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
