DangerRanger94 Posted October 20, 2013 Report Posted October 20, 2013 As far as db lvl what do u think 2 sa8s in a ported box 1.2cu tuned to 34hz would do in a standard cab ranger? 94 Ranger Std. Cab Bagged and Bodied Audio under construction: Center Console Ported Wall 4x SA-8 D2 Soundqubed 2200d.1 @ 1Ohm Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721 2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro 4x Fosgate Punch 300.1 Big 3 Upgrade Kandywirez XS D3400 09 Lancer Turbo 1- 12" DD 512B SoundStream Rub1000.1 (turned way way down) Avix-930bt
john253a Posted October 20, 2013 Report Posted October 20, 2013 http://m.youtube.com/watch?v=yoxfFsid3qs&desktop_uri=%2Fwatch%3Fv%3DyoxfFsid3qs Spl will come down power, as your box is already worked out My box is 1.2 @ 33 and I love it But if you want more spl idd rune it higher
DangerRanger94 Posted October 20, 2013 Author Report Posted October 20, 2013 Tune it higher as in like what 40hz? Would I be better going with 1 sa8 tuned higher? Or 2 tuned higher I don't have much room to play with its going in a single cab ranger with a body drop so the floor is actually raised up a bit so its pretty small 94 Ranger Std. Cab Bagged and Bodied Audio under construction: Center Console Ported Wall 4x SA-8 D2 Soundqubed 2200d.1 @ 1Ohm Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721 2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro 4x Fosgate Punch 300.1 Big 3 Upgrade Kandywirez XS D3400 09 Lancer Turbo 1- 12" DD 512B SoundStream Rub1000.1 (turned way way down) Avix-930bt
john253a Posted October 21, 2013 Report Posted October 21, 2013 What's the measurements See what fits and go from there What amp do you have? And what do you lesion to so was what to tune it to
DangerRanger94 Posted October 21, 2013 Author Report Posted October 21, 2013 I have room for 3 sa8s I think at about .60cubes for each sub so about 1.8-2.0cube box for 3 sa8s sundown 2500.1 94 Ranger Std. Cab Bagged and Bodied Audio under construction: Center Console Ported Wall 4x SA-8 D2 Soundqubed 2200d.1 @ 1Ohm Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721 2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro 4x Fosgate Punch 300.1 Big 3 Upgrade Kandywirez XS D3400 09 Lancer Turbo 1- 12" DD 512B SoundStream Rub1000.1 (turned way way down) Avix-930bt
DangerRanger94 Posted October 21, 2013 Author Report Posted October 21, 2013 Also they will be down firing btw 94 Ranger Std. Cab Bagged and Bodied Audio under construction: Center Console Ported Wall 4x SA-8 D2 Soundqubed 2200d.1 @ 1Ohm Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721 2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro 4x Fosgate Punch 300.1 Big 3 Upgrade Kandywirez XS D3400 09 Lancer Turbo 1- 12" DD 512B SoundStream Rub1000.1 (turned way way down) Avix-930bt
ChevyBoy95 Posted October 21, 2013 Report Posted October 21, 2013 No clue, build it and meter it, only way to know. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
DubNDodge Posted October 21, 2013 Report Posted October 21, 2013 Do you want it to be loud on music or loud on test tones? Loud on music = tune lower (30-34ish) Loud on test tones = tune higher If you aren't going to compete then don't worry about numbers. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
DangerRanger94 Posted October 21, 2013 Author Report Posted October 21, 2013 going with a different set up now its going to be a center console wedged wall with 4- DC 8s port facing winshield. about .65cubes for each sub on a sundown 2500.1 or 2 sundown 1000.1 dont know yet for sure. what u think would be better? 94 Ranger Std. Cab Bagged and Bodied Audio under construction: Center Console Ported Wall 4x SA-8 D2 Soundqubed 2200d.1 @ 1Ohm Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721 2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro 4x Fosgate Punch 300.1 Big 3 Upgrade Kandywirez XS D3400 09 Lancer Turbo 1- 12" DD 512B SoundStream Rub1000.1 (turned way way down) Avix-930bt
john253a Posted October 21, 2013 Report Posted October 21, 2013 For started Numbers and down firing don't go together Second you want help and have given no answers to any questions ask So how do you plane to receive the correct info If you want numbers 2.2net 40sq" of port at 42hz Is the most idd go and stay musical But on a sax2500 if you ain't careful they won't last If you something that will do both 1.8net 30sq" at 37hz Or if your into more low end style music 1.8net 25sq" at 32-33hz
