Miguels Posted October 22, 2013 Report Posted October 22, 2013 if you race and will be keeping it high rpm i would suggest a bigger pulley on the HO alt.. the small pulley they have can damage the alt at high rpm's you can use a stock pulley but you wont get the same performance out of the alt my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
420c Posted October 22, 2013 Report Posted October 22, 2013 No downside system wise but I think I read somewhere that you might loose horsepower (3-5), that could've been for multiple alts so don't quote me on that but I'm sure some of the vendors on here could better inform you. Don't under power that amp though or you'll end up smokin it.
Miguels Posted October 22, 2013 Report Posted October 22, 2013 the downside is you cant have both worlds. you either have a race car or you have an audio car.. for the amount of power you want to run you will need heavy batteries that will hurt your times and the weight will also hurt your stopping and your handling.with all the high speed turns you even run the risk of flipping over or tossing batteries around making your car short and catch on fire. get another car you can go crazy with the audio. my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
STEvil Posted October 22, 2013 Report Posted October 22, 2013 1hp per 750w, plus a bit for inefficiency. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
2LOUD Posted October 23, 2013 Author Report Posted October 23, 2013 Would this wiring kit be enough to run from the engine bay into another battery in the boot, into a distribution block then to the Sub Amp & Speaker Amp. http://www.stingerelectronics.com/productDetails.aspx?ProductId=697&CategoryID=1 http://www.stingerelectronics.com/productDetails.aspx?ProductId=595&CategoryID=13 Also thoughts on grounding the amps at two points on the body in the boot or too the battery in the boot? How fuses should I be running and would a single 300A be enough?
Guest Posted October 23, 2013 Report Posted October 23, 2013 idk why lanzar thought it would be a good idea to put only one set of 1/0 power terminals on that amp. it should use two sets really. you can either do like one run of 2/0 from front to back, then 1/0 into the amp from the back batteries. or get 2/0 to 1/0 converters from sky high http://www.ebay.com/itm/Pair-Sky-High-Car-Audio-2-0-Gauge-1-0-Gauge-Amp-Input-Reducers-FREE-SHIP-/281159144552? or get a 2/0 kit from sky high. thats what i'd do. 2/0 from front battery to one rear battery, then hook up the rear batteries together with a run of 2/0. ground with 2/0. then into the amp with 2/0 and the 2/0 to 1/0 converter that i linked to. http://www.stevemeadedesigns.com/board/topic/176059-sky-high-car-audio-amp-kits-and-big-3-kits/
Kyblack76 Posted October 23, 2013 Report Posted October 23, 2013 IMHO Leave the ECV be,... Do a system in a different ride. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
killallblue Posted October 23, 2013 Report Posted October 23, 2013 idk why lanzar thought it would be a good idea to put only one set of 1/0 power terminals on that amp. it should use two sets really. you can either do like one run of 2/0 from front to back, then 1/0 into the amp from the back batteries. or get 2/0 to 1/0 converters from sky high http://www.ebay.com/itm/Pair-Sky-High-Car-Audio-2-0-Gauge-1-0-Gauge-Amp-Input-Reducers-FREE-SHIP-/281159144552? or get a 2/0 kit from sky high. thats what i'd do. 2/0 from front battery to one rear battery, then hook up the rear batteries together with a run of 2/0. ground with 2/0. then into the amp with 2/0 and the 2/0 to 1/0 converter that i linked to. http://www.stevemeadedesigns.com/board/topic/176059-sky-high-car-audio-amp-kits-and-big-3-kits/ they changed it for the 7k other then that it is the same amp
