Battery Bank Charger
This might seem like a stupid question, but I searched and could not find an answer. How do I figure out what charger I need to keep a battery bank maintained? I will be running 5 XS Power d3100s in my bank so 550 AH. My goal is to be able to charge them all at the same time without having to disconnect any of them. I am worried that the 550 AH might confuse a smart charger into thinking it is a fully charged single battery if that makes since.
2000 Toyota Camry With Sealed Off Trunk
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
Two DC Level 4 m2 12s
80 Mil Murdetmat
Gathering Parts For Wall Build.
Team DC Audio 2014 Member
The CTEK MULTI US 25000 advertises 500Ah.
XS Power doesn't specific a certain Ah rating, but the manual for the 1005 charger shows the below formula that you can use to determine what you need.
How many batteries can I recharge at one time with the IntelliCHARGER?
This depends on the size of the batteries. All batteries in the bank must be of the same type and
size. In addition, the IntelliCHARGER is expecting the battery bank to be at full charge in ten
hours or less. Therefore the size of the batteries and their depth of discharge will play a role in
the answer here. Given they were all XS Power 16V AGM batteries with a size of 45Ah at 100%
discharged, you can charge up to four in parallel in ten hours.
Calculating external Battery Charging Time
Charging time will depend on the amp-hour capacity of your battery and on how deeply it is
discharged. The following equation calculates an approximate charging time:
Charging Time = (CAP x DOD)/(CC x 80%) where:
Charging Time = Battery recharge time in hours
CAP = Battery capacity in amp-hours
DOD = Battery depth of discharge in percent.
A fully discharged battery has 100% DOD.
CC = Charge current. The rated current output of the
charger in amps.
80% = Typical charging efficiency for lead-acid batteries.
Example: An XS Power 16V AGM battery rated at 45 amp-hours is 60% discharged, that is, it has a DOD = 60%.
Charging time with an IntelliCHARGER 15A unit is calculated as follows:
Charging time = (45Ah x 60%)\(25A x 80%) = 1.35 hours
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
charger in amps.
Based off this formula if I take the 550 AH I will have and figure the batteries are half dead at 275 AH total charge needed with the intlicharger set to 25 amps I should be able to charge my bank in 6.875 hours which is under the stated 10 hours charge max. So if I am understanding this correctly that charger should work without a problem.
Budget?
The chargers from xs are the way to go if you can swing it
As far as budget I am not worried about that. I am going to have over $3000 in electrical anyway so I want the best charger that I can get to make sure I do not ruin $2000 of batteries.
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
SHould I hook the positive to the D3100 under the hood and the negative to the last D3100 battery in the rear bank to charge all 5 at once properly?
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
The batteries are all in parallel therefore the positive connections are all the same as well as all the negatives.
Doesn't matter where you connect on the battery bank as long as positive goes to positive and negative to negative.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
What about this charger. It has all the same features as the xs power 1005 plus it can charge 3 seperate banks at a time and is 30 amps vs the 1005s 25 amps so it would support a bank of roughly 10 d3100s by itself. It can also be used as a 30 amp power supply to test audio equipment.
http://www.summitracing.com/parts/sxa-08302?seid=srese1&gclid=CJyPhZ3vqroCFUVp7AodYGgAjA
Sky High OFC Wiring
DC Power 270 XP Alt
AQ 2200 Sub Amp
80 Mil Murdetmat
  • Who's Online   0 Members, 0 Anonymous, 2742 Guests (See full list)
