i am buying a audio technix 800.1 (http://www.ebay.com/itm/Audio-Technix-800-1-amp-amplifier-800w-RMS-2000w-MAX-Class-D-1-ohm-stable-/111053236151). Would i be ok if i was running it on stock electrical (2000 grandprix gtp), or should i add a extra batt and do big 3. an alt is out of budget right now.
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
A extra battery and big 3 would help anything over 600rms I've upgraded the battery and done a big three. I'd say u would be ok on stock but may have some light diming issues I had a 2001 grandprix with two soundstream 600rms amps and I got the dims till I upgraded battery and did the big 3. XS makes a good battery if not the best for audio
94 Ranger Std. Cab Bagged and Bodied
Audio under construction:
Center Console Ported Wall
4x SA-8 D2
Soundqubed 2200d.1 @ 1Ohm
Pillar Pods 2x Fosgate P132 - 2x Audiopipe ATR3721
2x Fosgate PPS4-8 Pro - 2x Fosgate PPS4-6 Pro
4x Fosgate Punch 300.1
Big 3 Upgrade Kandywirez
XS D3400
09 Lancer Turbo
1- 12" DD 512B
SoundStream Rub1000.1 (turned way way down)
Avix-930bt
I would start by doing the big three upgrade first.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
Be aware that if you just do the big three it might make your light dimming worse, thats what happened to me in my car but then I got two agm batts for under the hood and had .3 voltage drop on a Hifonics Brutus 1700.1 @ 1ohm. And we all know how inefficient the Brutus amps are, so I say once you upgrade your battery and do the big three you'll be good, but to me one without the other kinda defeats the purpose.
THE ANTHRACITE DYC CRUISER
-Fully dipped anthracite grey pt cruiser
-4 skar vvx 12's (version 1)
-Mechman 240 amp alt -Big three in Cadence 1/0
-1 deka intimidator g31 blacktop under the hood
-1 C&D 140ah Batt & 1 C&D 55ah batt in the rear
-Re audio/soundstream mids and highs
-Hifonics Zues 600.4
-DC Audio 3.5k
Like i said up grade battery and do a big 3 youll be good
4x SA-8 D2
XS D3400
09 Lancer Turbo
1- 12" DD 512B
Avix-930bt
i was planning on doing the big 3 this weekend if i had time after doing my brakes (completely gone hopefully maser cylinder) and could i just put a cheap 2nd batt in the trunk for a while until i have money for it..im only 17 and no job at the moment so moneys tight.
yes you'll be good for that big 3 and add a 2nd batt it may dim still.
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
lol my aq 1200 AND a rockford 200a4 barely made my voltage drop while driving. and OP has an alt thats like 40 amps bigger than what i had.
all i had was the big 2 and a stock walmart wetcell under the hood.
Try it and see what happens. If you dim too much you will have your answer. We can't give you a definite answer only to find you frustrated and disappointed. Just be smart about it and don't hammer on it while at idle.
BTW nice car. I loved my parent's gtp when they had it. My step dad put the wrong coolant in and killed it though (reading the fucking manual helps).
Eclipse cd7000
Try it and see what happens. If you dim too much you will have your answer. We can't give you a definite answer only to find you frustrated and disappointed. Just be smart about it and don't hammer on it while at idle. BTW nice car. I loved my parent's gtp when they had it. My step dad put the wrong coolant in and killed it though (reading the fucking manual helps).
Thanks is have worked my ass off for it and put a shit ton of work in it already. Just wanted opinions b4 in put the amp it. I'm just don't want to kill the alt.
  • Who's Online   1 Member, 0 Anonymous, 3315 Guests (See full list)
