Fuse size for Singer ALT
Thinking about getting a Singer 350A alternator but wanted to make sure on my fuse size. Being a 350 alt I am assuming that I will need a 350A fuse running from the alt to the first battery and then also a 350 on the way back to my second battery. Is this correct here or am I over thinking this. Will be running a XS Power 3400 up front and a 3100 in the back (will get a second 3100 in the back when I can) Two runs of 1/0 guage off the alt to the battery and two runs from the front battery to the back. Sky High OFC in a 07 Trailblazer. Thanks.
http://www.stevemeadedesigns.com/board/topic/177477-slowboring-07-trailblazer-build/
Pioneer DEH-80PRS
PRV 8MR400-NDY (eight)
PRV TW350Ti (6)
Sky High 1/0 OFC, 12 gauge and 8 gauge
TM Metalworkz battery terminals
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
American Bass SQL3200
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
dont fuse the alt charging lead, there isnt really a point. Fuses dont protect from voltage spikes.
But fuse the power runs at WHAT THE WIRE CAN HANDLE. If you have a 400a alternator, and 1 run of 1/0 CCA that can only carry 200a, if you put 400a of fusing in that CCA you are going to end up melting the jacket, and burning/shorting something.
in your case of having 1/0 OFC, use a 250a or 300a fuse per run of wire. If the wire is over 20ft long, use a 250a fuse.
You aren't fusing for voltage spikes, but for a possible short.
Eclipse cd7000
ok so for what I have I need to have two runs from the alt to the 3400, no fuse. two runs from the 3400, fused about 10 to 12 inches, to the 3100 in back, fused 10 to 12 inches before the 3100 and then fuse from the 3100 to the two amps. So basically a fuse on each run within 10 to 12 inches from each battery, (two fuses on each run) and then a fuse from the back battery to each amp correct?
Pioneer DEH-80PRS
PRV TW350Ti (6)
120 sqft Hushmat
XS Power D3100 (6)
Singer 350 Amp Alt
Singer 320 (2)
JL Audio JX360/4
Crossfire XS 8K (2)
DC Audio XL 15s (6)
  • Who's Online   0 Members, 0 Anonymous, 1351 Guests (See full list)
