KiKaZz74 Posted October 27, 2013 Report Posted October 27, 2013 I have a 1997 dodge dakota sport 5.2l 4wd and as anyone who owns one knows. The gas mileage is shit. I'm looking to upgrade to a electric fan to save me some gas. I'm not finding any kits tho. Not looking to spend more than $200 for everything unless its impossible. But what's everyone recommend? I saw someone say a ford taurus kit worked but I'd like some more input. Thanks guys. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
Tarball Posted October 27, 2013 Report Posted October 27, 2013 you can piece one together. I recommend a dual speed or dual fan kit. That way you can tap one fan/speed for temp and the other when your AC compressor kicks in. I converted my S10 to eFan with a temperature kit, a couple of relays and a junkyard fan. Just measure out when you need and browse the local scrap yard. Edit: My mileage is still crap but I haul around a few hundred pounds Subs, box, amps and wire. Not to mention the strain of the H.O. alt on my little 2.2 CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
KiKaZz74 Posted October 27, 2013 Author Report Posted October 27, 2013 Oh I should mention. My ac doesn't work. Bad leak so my compressor just does the hellacious noise when it kicks in. My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
KiKaZz74 Posted October 27, 2013 Author Report Posted October 27, 2013 What's ur mileage before and after? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
Turboelky Posted December 11, 2013 Report Posted December 11, 2013 not sure if you've got your electric fan set up yet or not. But keep in mind, while you will gain maybe 1-2mpg and power, you'll be pulling 30-40 amps of power just for the fan/s .
Miguels Posted December 11, 2013 Report Posted December 11, 2013 the amp draw gets lower once the fans are spinning.. usually the draw spike happens when they just turn on my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
Turboelky Posted December 11, 2013 Report Posted December 11, 2013 I was actually talking continuos load. Some electric fans can pull upwards of 90 amps on hard start! Only reason I haven't went to a electric fan in my TBSS is because the electrical draw. Once I get that mechman ^^^ I'll be doing that upgrade
KiKaZz74 Posted December 11, 2013 Author Report Posted December 11, 2013 Well thats good to know. Maybe ill just have to keep clutch fan. It sounds like its going out thoughm maybe get a plastic blade or something not so massively heavy. Any ideas on that? My SPL to SQ Build Log Vehicle:1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT5.2L V8 Magnum 3.5L V6 Stock AltEquipment: Headunit- Alpine CDE-147BT Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12 Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy Mids- Dayton Audio Reference 4" Full Range Drivers Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5" Processor- MiniDSP 2x4 RCA- 6 channels of SounDrive HF series Wire- EB Flex 2/0 -Member of Team SounDrive
