Mono amp for Midbass?
nocturnalrites101
Why would you want to mono your mid bass ???
I'm planning to run a pair of amplifiers mono on my mid bass ... one amp for each mid bass driver (one in each door) ...
you will lose left and right channel separation
... and you would want a stereo amplifier for midbass ... not a sub amplifier
Copied this directly from the website you listed ...
The Power T500-1bdCP is a 500 Watt mono amplifier featuring Constant Power delivering up to 25% more power across all impedance loads.
The frequency response of the T500-1bdCP is optimized exclusively for use with subwoofers.
I can read i know its a subwoofer amplifier but it also responses from 25-250 hz . Im saying if i need more power, and my cut off point is below 250 hz , would it work.
it was just a theoretical question , ive found a back up amplifer that is stereo anyway
Would it work ?? Seems like it would on paper ...
Would I set it up in my sound Quality truck ?? No Sir, I would not ... My mid bass drivers play 500 htz down to 40 htz (time aligned) ...
All I'm suggesting is to run a class A/B full range stereo amplifier on your midbass drivers ...
Of all the ones to listen to when it comes to sq...cableguy is the shiznit.
(just don't tell him that though..his head will get humonginoid!)
10501650_10203332501847103_1859383749711
Blown
  • Who's Online   1 Member, 0 Anonymous, 757 Guests (See full list)
