How much port area for an 18?
JesseyMclame
Okay so I've got An M1 XL 18 with psi soft parts, ittl be getting right around 1800-2000 watts, I'm gonna do 5.5 cubes after all displacement, (came from rusty), I'm gonna do aero ports, I just have no idea how much port area to give it. I'm thinkin like 10-12 SQ inches per foot ? Any input would be awesome, thanks guys!
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
Do yourself a favor and forget about the sq in per cube "rule", because it is a complete myth. Port area does not relate directly to volume of the enclosure. Factors that do matter are the tuning frequency of the enclosure (Fb), the xmax of the sub, cone area of the sub (Sd), and of course the number of subs. You know the T/S parameters of a speaker? Created by A.N. Thiele and Richard H. Small? Small derived a formula to calculate the minimum port area required to avoid port noise and compression.
Following his formula you get MINIMUMS of:
77 sq inches at a tuning of 20Hz
115 sq inches at a tuning of 30Hz
134 sq inches at a tuning of 35Hz
With your "rule", 5.5 cu ft with 12 sq in per cubic foot would only get you 66 sq inches of port. This is far too small for an 18" subwoofer, its not even enough area if you were to tune to 20Hz which I doubt you are planning.
Chevrolet Tahoe
Crescendo PWX6 (2) and FT1 (2)
Fi Audio SP4 15" (1), AQ3500D.1 (1)
Enclosure: 4th Order (Ported) 4.5cu ft @26Hz
Mechman Elite 370A & Kinetik HC2000
Sky High 2/0 Wire
Future Plans: (2) 18" @25Hz
You're a new member, but I like you already^^^
Great info and I agree we need to throw the "per cubic foot" rule out the window.
Okay so pretty much, no matter the net volume of the box, those are the minimums I need to make the speaker sound it's best at that tuning frequency?
Alt - Singer 330A
Or more so, let the woofer work proper in said enclosure.
Alt - Singer 330A
To expand on what Rail said, the formula I use is:
Vd (Volume of the driver in cubic inches) * Tuning Frequency (In Hertz) * .02 = Area of the port (In square inches)
This formula is pretty conservative and should keep your port velocity under 10 meters/sec.
If you don't know the Vd of your driver you can calculate it, its Sd (Cone area in square inches) * Xmax (In inches) * 2.
Builds:
using sd you'll be looking around 130sq" and thats just crazy in 5.5 net
3x 6" at 17 long (psp) is what idd use and block 1 off for daily
edit:
that is if you don't want low 30's tune,
you will get better performance form you equipment with a larger port, just you'll be hard to get 3x 6" 41" long @30hz in a 5.5net box
Thanks! New member, but not new to car audio
Yes, in order to avoid port noise and port compression due to high air velocity.
Small's formula is actually:
39.37 * (Fb*Vd)^(1/2)
Fb is the tuning frequency of the enclosure
Vd is the amount of air that the sub can displace (which is cone area times the xmax, so Vd = Sd*xmax)
This will get you the minimum diameter of the port in inches, so if you divide by 2 to get the minimum radius, you can then use pi*r^2 to find the minimum area of the port.
Edit: To make this more clear, you must convert both the Sd and Xmax to meters, so that for the Vd you get cubic meters.
Chevrolet Tahoe
Sky High 2/0 Wire
The setup in my sig only has 86 sq in of port and it sounds great. No port noise whatsoever.
FI BL18 Build Log: CLICK HERE!!
2003 Explorer Sport:
FI BL18
SoundQubed 2200 at 0.7ohm
Pioneer DEH-2500UI
Pioneer 6 x 8s
Rockford Fosgate 6 x 9s
5 ft^3 box at 35hz
Lots of Mega Mat
SkyHighCarAudio_zpse6b4e501.png3abb2365-8d29-422d-a446-efa7a74b8dba_zps70e62980.jpgFILogo_zps400b37c1.jpg
The formula I gave is Small's formula, its just been worked around to use Vd in cubic inches instead of cubic meters and to give you your result in square inches of areas instead of the diameter of a round port.
Also to calculate Vd you have to multiply the Xmax by 2 since it is a measurement of travel each direction.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1150 Guests (See full list)
