Bump4life's SuperCapacitor Overview and Testing
If you are using blue caps and only run up to let's say 15.5 volt max then you don't need balancing circuits BUT if you plan on running let's say 17.0 volt on 6 blues per bank then balancing is a must.
how do you run 6 caps at 17? dont you need 7 in a bank?
i think what he's trying to get at is if you're charging really close to their max voltages where a imbalance in the caps would cause one to go over that voltage then a balancing circuit is a must. but yeah, i would definitely not run 6 at 17V :P as much as i love the smell of exploding caps....
I think you have a bit of truck stuck in your mud bro
~Ford Ranger, ext cab
Kenwood DDX470
1/0ga stinger wiring for big 3
1/0ga ofc flextech wiring
3 kinetik 800's
AQ2200 @1ohm
Sundown Audio X15
in a 27Hz tuned ported box
LE BUILD LOG!!!
wish you have tested with the termlab, nice topic!
makes me want to buy more caps now.
i can guarantee its louder. you are holding a higher voltage and pretty much have as much amperage as you could want on tap. there is no reason batteries would be louder
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
Why can't you charge to 17.0 with 6 blues? 2.7 x 6 is 16.2 and 2.8 x 6 is 16.8 so .2 more volt is not gonna hurt a thing.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
My cap bank is of blacks but I just got 96 more blues so :)
Evo X build log
Great info in this thread. I will be getting caps.
2007 Ford Focus SES Hatchback
Pioneer HU
4 Digital Designs 9515i's in a B pillar.
2 Soundstream XXX 15K's (running at 16 volts)
Soundstream Mids/Highs in custom door panels (getting rebuilt soon)
Soundstream TA2.160 and TA2.400
Sky High and KNU wiring
3 Banks of Maxwell caps
Winston Lithium (not a fan)
Bump4Life 250 Amp Alt. aka USAlternators
Soundstream Focus and Avenger Build Log
Instagram @p4linnovation
YouTube: Team Blowin Loud
I use to have blacks an used them with blues .. When I bought blacks in eBay few years back I had 9 out if 12 bad they leaked or didn't charge .. I was always weary of hooking in series to amps because of this .. The way I did it was one pos from batt to amp dual input the other from cap bank to dual input .. Had some amp failures wasn't sure why but found two bad caps on my banks .. Question should grounds come from battery or frame .. I know there's a lot of current going through wires .. How many banks of blues for 20 k I have 4 now which helps with battery's but I know I need more just no room
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
  • Who's Online   1 Member, 0 Anonymous, 1817 Guests (See full list)
