Port Tuning
iTac91
My subs (JL 10w0) call for a port tuned to 30 hz. I found a box with everything right except the port is tuned to 40 hz. How much of a difference will this make.
The port is an inch too wide. Could i just add half an inch to each side of the vent and fix it or would i have to move the interior lengths aswell.
30 to 40hz is a huge difference. You ever notice how most prefab enclosures are really loud at higher frequencies, but have little to no low end? That's because they're tuned to 40+. Something tuned to 30hz will have FAR better low end, but may not hit the 40hz as well.
Depends what the port area/ft ends up at. If it's at say...12, you could just lengthen the port a few inches as long as it doesn't change your /ft to 16+ or lower your overall volume too much. Get torres box calc. Mess around with a few different port dimensions and see what works. But in all honesty, you'd probably be best off just rebuilding your own from scratch.
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
I went from 30hz to 35 hz. Never again will I go over 30hz.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Not to mention a 40 Hz tune is probably going to have a HUGE peak in the response and be really boomy. Lower tuning = better, at least in my opinion, and I'm not alone.
Builds:
You should probably post a sketch of that box, there are a few ways to change tuning to an already made box but is hard to recommend something without looking at it.
I think this depends on the subs you are running. Most of the more experienced box builders I have sought out for advice did not recommending tuning that low.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
  • Who's Online   0 Members, 0 Anonymous, 5740 Guests (See full list)
