Help with spray painting and gloss
Im posting here my question to see if anyone has experience with spray painting parts. Well im using Rustoleum Gloss black paint and everything looks real good, but as soon as i apply the Rustoleum crystal clear enamel the whole nice paint job goes down to the crapper. I have wet sanded it and then applied the clear over it but the clear always cracks and lifts up and looks horrible. I want to know some tips and tricks that you guys might have to apply the clear and being smooth as glass and not looking all wrinkled.
You're putting a clear coat over which gloss black? Most gloss paints are finish coat paints. Probably the two are not compatible and that's causing your issue especially if the black is a lacquer and the clear is enamel.
Check with the paint store or Rustoleum DIY painters forum via Google.
Static drops are my bag.
im using Rust-Oleum Gloss Protective Enamel (black) and Rust-Oleum Crystal Clear Enamel. But it still cracks i even applied the clear right after the paint and it cracked a little bit but it was not glossy. Both are enamel.
Youre painting too thick
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
What are you painting by the way? Are there base coats or primers you are using as well?
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Mids/Highs: Alpine SPR-50c 5.25" components
Mids rear: Alpine SPR-69 6x9
Mids amp: Alpine MRX-F65
Power/Ground: Massive Audio 4 AWG
Signal Cable: Massive Audio 14 Gauge
RCA's: Monster cable
Subs: 2 Rockford Fosgate HX2 12's
Sub amp: Crescendo BC2000D
Custom box - Herculiner with Silver port
Big 3 and power/ground - Sky High Car Audio 1/0 OFC
Coming soon:
H.O Alternator Singer or Mechman
i use the automotive spray can paint color and clear coat from advance auto, forgot the brand name, on metal wood and fiberglass. no issues.
03 s-10 owned since 35k now 150k
alpine type-s 6.5 comp
alpine type-e 10 ported fiberglass
jl 300/4 (dead)
jl500/1 (dead)
either too thick or let it dry alittle longer between coats
. it snowing buy me! not sure where you are at. let it dry longer or gotoi that forum he said
jl 300/4 (dead)
jl500/1 (dead)
For your top coat use lacquer. Enamel takes too long to flash over and dry. You need to wait atleast 1 day to apply your top coat. Lacquer will flash over fast and will not activate your coating underneath it. Take your time and let the black dry for 24 hours. Use a car paint lacquer for top coat. Autozone and any of the car parts store will have it. Home Depot has lacquer also. Try not to use rustoluem for top coat!!
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
24 hour drying is not necessary
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Wait 24 hours. Enamel is not the same as lacquer. You are activating your base coat because it is not dry and your base coat fumes needs somewhere to go and it is making your top coat crack because it is still putting of gases from drying. It may feel dry but it is not. Been spraying lacquer and enamels for 32 years in cabinet shop.
You are rushing your drying process. The more base coats the more drying time.
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
2-5.25 Satori Mids
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
