scobar Posted November 10, 2013 Report Posted November 10, 2013 I have a polk c400.4 I bought used. Seems to work, however there is a very audible pop/click when turning my deck on or off. My old amp did not do this. I've re-grounded the amp twice. Truck has big 3 done with 1/0, D3400 bat, mechman alt, etc. Just puzzled...google seems to suggest potential filter caps. Never been inside of an amp before but handy with an iron. Thoughts?
03 Xtreme Fosgate Posted November 10, 2013 Report Posted November 10, 2013 This is the reason I don't like buying used equipment. Maybe get one of those remote turn on modules to help with turn on pop? BUILD LOG-http://www.stevemeadedesigns.com/board/topic/179004-03-s10-xtreme-ext-cab-rf-build/ PHOTOBUCKET- http://s1354.beta.photobucket.com/user/03XtremeFosgate/library/truck%20audio%20rebuild
hazestorm23 Posted November 10, 2013 Report Posted November 10, 2013 Is the notice in the speakers or amp itself? Try removing rcas then turning it on
rockFord_Expedition Posted November 10, 2013 Report Posted November 10, 2013 See if this fixes it and report back: Disconnect the remote turn on lead and make sure it doesn't touch anything and leave everything else hooked up. Do this with the system off and no key in the ignition. Turn on your car/system and make sure the volume is all the way down. Connect the remote wire after your system has been on for a few seconds. Lemme know what happens. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
justin0943 Posted November 10, 2013 Report Posted November 10, 2013 its just the amp what it is doing it stays on a little longer then the radio causing that pop 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
rockFord_Expedition Posted November 10, 2013 Report Posted November 10, 2013 If my suggestion fixes your problem there are several ways to fix it. Installing a switch inline, relays, etc. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
scobar Posted November 10, 2013 Author Report Posted November 10, 2013 Is the notice in the speakers or amp itself? Try removing rcas then turning it on Same thing with or without them. I'll try some other ideas later.
jmfrb1 Posted November 11, 2013 Report Posted November 11, 2013 Same thing happened in my girls ride. I hooked up an on/off switch to the remote wire and would turn it on a few seconds after the radio came on and turn it off before turning the radio/vehicle off. Worked like a charm man
scobar Posted May 4, 2014 Author Report Posted May 4, 2014 Ok finally got my truck back. With everything off I can jump the remote and it pops on and off. Urg!
rockFord_Expedition Posted May 5, 2014 Report Posted May 5, 2014 Ok finally got my truck back. With everything off I can jump the remote and it pops on and off. Urg! Who suggested that you do that? If you are referring to the advice I gave you, that isn't what I said. Old School/New School RF Build March 2015 SOTM Winner How to crimp large wire
