2009 GT-R SQ Audio Build ( Morel, Mosconi and Illusion Audio)
hmm....Been thinking about this car and doing an sq set up in it....now you really got me thinking.
don't tease us
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Next the trim adapter rings were routed and coated for the door and door panel.
the oem 3 way speakers side by side with the morel components.
Next the door was covered with focal bam xxxl and blackhole tile.
Toxic Orange 2011 HDP Dodge Challenger RT
Universial Air Suspension
22" Kartier Forged wheels
Flowmaster American Thunder Cat-back
soon to come audio build
- Ground Zero Hydrogen 30x subs
- Ground Zero Plutonium 3 way components
- singer wiring and accessories
SQ Build Logs
Facebook https://www.facebook.com/pages/Hinnant-Design/102693809895087
Then the woofer adapter and woofer were mounted to the door.
Then the door panel received the same treatment.
SQ Build Logs
The same was done to the passenger side.
SQ Build Logs
Next speaker wires, remote wire( fused at fuse box) and 0 gauge power wire are routed on the driver side.
SQ Build Logs
sick car! keep the pix coming! :)
Follow my Tweet (Twitter)
Moving on to the building process of the mdf enclosure. enclosure size is 1cu ft.
SQ Build Logs
Oem amp front full range signal was tap into for signal to the Mosconi 6to8.
Also applied focal bam xxxl to fender areas and noisy sheet metal areas
SQ Build Logs
SQ Build Logs
