2009 GT-R SQ Audio Build ( Morel, Mosconi and Illusion Audio)
filler was added and lots of sanding to get a contour look rather then a plain flat trim panel.
Toxic Orange 2011 HDP Dodge Challenger RT
Universial Air Suspension
22" Kartier Forged wheels
Flowmaster American Thunder Cat-back
soon to come audio build
- Ground Zero Hydrogen 30x subs
- Ground Zero Plutonium 3 way components
- singer wiring and accessories
SQ Build Logs
Facebook https://www.facebook.com/pages/Hinnant-Design/102693809895087
those amps.. those mids and highs, the fabrication.. you are talented. and man what a vehicle to work on, Stripping one of those bolts and your F'd. balls of steel
Build's consist of:
2004 Chevy Impala :
Pioneer--------------------- DEH-X8600bs Soundqubed/AQ------ Q4-120
Rockford Fosgate---- Punch-500.4
Soundqubed/AQ----- Q1-3500D.1 Alpine----------------- 6.5's & 6x9's
Subs: TBA All Knukonceptz and SHCA wire and rca's
Home Music Setup
(4) Soundqubed HDS200 15's in two separate 15.5 cubic foot enclosures tuned to 31 hrz --- XM radio hardwire
Updates coming all the time on both builds
n8ball2013
"bullshit. Everything fits. If you cut enough."
That car.. That deadener... That front stage....
My god..
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Finished trim panel for the system. Test fitted in the car after being wrapped in trunk liner. pressure fit and Neo magnets are used to attach and hold the trim panel in place.
SQ Build Logs
True test of whether that panel will stay put is to do a hard launch in that bish
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
0 gauge Power run from under the hood, and some engine pics.
SQ Build Logs
SQ Build Logs
So thats it guys completed SQ GTR. sounded awesome, sub blended very well with the front stage and got very good output from the single 12.
SQ Build Logs
