EKCASA 1993 CHEVY C1500 EXT CAB
Thanks Smoove
3bc3a7ec-d90c-40a7-928f-eef8c019b42b_zpswww.facebook.com/EKCASA
System:
All Rockford Fosgate
Front: 2 Pair Prime 6.5's and 1 pair Prime 5.25 Components
Rear: 1 Pair Prime 6.5 3 Ways
Subs: 4 Prime R2D2-12's
Amps:
Front: Prime R250X4
Subs: 2 Prime 500X1d's
HU: JVC KD-AR959BS
2 Optima Yellow Tops
Singer 230A H/O Alt.
Lots of KnuKonceptz 1/0 and accessories
105 Sq ft Kno Knoise deadener
I'm not a fan of that port design. Those subs don't need much port area, but the aspect ratio is an important thing to factor in for efficiency of the port. 1:1 is ideal(think a perfect circle), like Meade's square port.
You have over a 12:1 ratio :( . You may experience port noise but I doubt it. Your port just isn't as efficient as it should be and your listening experience could suffer from it. A port with a better aspect ratio(closer to 1:1 than you are now) would be much better.
Yeah port noise was my main fear, seems to be OK though. My target is 140 which with this setup shouldn't be an issue. if it doesn't make it a redesign is definitely going to happen. this is my fist ever ported box. every owned, ever built. nothing will be final on it until it hits the meter which should be next weekend. even then the subs won't be broken in so I will still be under powered. You guys know the drill, "It's never loud enough!"
System:
Amps:
Front: Prime R250X4
HU: JVC KD-AR959BS
System:
Amps:
Front: Prime R250X4
HU: JVC KD-AR959BS
You wont have a lowend monster. But I bet you put up some high numbers. And it will be nice on music
You Sir were right. Definitely not a lowend setup. @ 65hz its the same frequency as the two 10s sealed under the seat that I was running before. The gains were not set correctly, they were actually a little low, i didn't want to hurt the subs since they're not broke in yet.
System:
Amps:
Front: Prime R250X4
HU: JVC KD-AR959BS
System:
Amps:
Front: Prime R250X4
HU: JVC KD-AR959BS
  • 7 months later...
Its been a while since I have updated the build going to try to post some new pics.
System:
Amps:
Front: Prime R250X4
HU: JVC KD-AR959BS
System:
Amps:
Front: Prime R250X4
HU: JVC KD-AR959BS
