Anyone with cap bank install?
I did a write up here on super caps and a little testing. No balancing circuits used though
http://www.stevemeadedesigns.com/board/topic/178148-bump4lifes-supercapacitor-overview-and-testing/
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I have an ~850 farad cap bank. You know how with voltage drop it's kind of all or nothing? Either you are holding 14v+ (or whatever your alt charges at) or you drop to 13v or lower.
Capacitors store energy. Not in the same way batteries do though. Batteries create energy though a chemical reaction - of which only takes place below the batteries "resting voltage". Capacitors store a difference in electrons - think like static electricity. This means they can absorb/release power at ANY voltage.
So in between your alternator's charging voltage and your battery's voltage potential (13v and below) - this is where caps shine. They basically act like a giant stabilizer. It cushions your drops, absorbs your peaks. I have a video of them which I'll post below. Been meaning to get a second one with the VM-1
that is just impressive results. 2 banks on how much power? a cross fire 8k? lol
BMW M340 xDrive
snowdrifter i believe has to banks, but he is also running xs p0wer 14volt battery, and charging above 16volts. Like you said @bump4life, higher voltage, equals higher capacity
*Hummer H3*
HeadUnit
Pioneer AVH-X4600BT
Mids and Highs
8-CT Sounds Pro 8" 8ohm
4-CT Sounds Pro Tweeters
Amplifiers
1-CT Sounds 125.4
1-CT Sounds 60.4
1-CT Sounds 7000.1
Electrical
3-Runs of 1/0 CT Sounds
8-XS Power D3100
3-Iraggi 300 amp Alternators
Subwoofers
4-SQ Hdc3 15" Subwoofers
(Soon to be 4 15" Ct Sounds EXO)
dirrrr
BMW M340 xDrive
I run 14v batts an 14 black caps an 12 blue ones.. Love my caps
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
yes but caps charge and discharge at a linear rate. so it doesnt matter what voltage they are used at. results should be same in a perfect world at any voltage as long as draw is the same
Linear..?
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capchg.html
Charging current asymptotically goes to zero as it charges.
Then it exponentially discharges.
Energy stored in a cap = 0.5 * C * V^2
Since voltage is squared, energy skyrockets as you increase voltage.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
Linear..?
Now now, lets not blow OPs mind quite yet :)
learn me :) lol guess i was thinking wrong thing. makes sense though.
linear. dirrrr, i have much to learn still
BMW M340 xDrive
Can you guys show some examples of balancing circuits
Alpine 9884
RF T2 comp set up front
The Epicenter
2x RF T10001bd
2x Sundown sa-15 t-line
Big 3
Smd DD-1
so say I bought an AGM battery with the big 3 upgrade on a 120 amp or bigger alternator would I be able to buy 2 supercapacitors like the ones @banginhummer posted
would that work on a 2k RMS system?
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
