Anybody know anything about open baffles?
Pretty much been looking into designing a few open baffle enclosures or variations on that.
Would appreciate anything anyone knows about them.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Open baffle?
Such as this.
I am looking for information on the amount of baffle needed around each individual driver to keep the direction of the front wave the way I need.
Edit: that picture seems to incorporate a bass reflex enclosure for the midbass/woofer
So kinda like free airing ?
750??! Yeah, fuck that. Fuck this website, fuck SMD, fuck Steve, fuck all of his butt buddy mods, and their couches.
^ DON'T BE A DICK LIKE THIS GUY :)
Team Subsonic Lows
A form per-say, but it is controlled and calculated to have the waves reflect off the baffle in certain ways.
That picture doesn't really represent the size of the baffle well, here is a picture to help out with size.
Infinite baffle?
Skar Audio SDR 10" x2 (Sealed Box)
Skar Audio 1500.1D (1 Ohm) x1
Skar Audio TX525c (Front with dash tweeter) x1
Kenwood Excelon KFC-X173 (Rear Coax) x1
JL Audio 360.4 (Mids & Highs Amp) x1
DEH80-PRS
XS Power d3400
Singer Alternator 275A
98 Jeep TJ 4.0 5 Speed
Infinite baffle?
no..
A variation on the 'open baffle' approach is to mount the loudspeaker driver in a very large sealed enclosure, providing minimal 'air spring' restoring force to the cone. This minimizes the change in the driver's resonant frequency caused by the enclosure. Some infinite baffle 'enclosures' have used an adjoining room, basement, or a closet or attic. This is often the case with exotic rotary woofer installations, as they are intended to go to frequencies lower than 20 Hertz and displace large volumes of air. "Infinite baffle" or simply "IB" is also used as a generic term for sealed enclosures of any size, the name being used because of the ability of a sealed enclosure to prevent any interaction between the forward and rear radiation of a driver at low frequencies.
Infinite Baffle:
These are great for applications where trunk space is at a minimum and usually the easiest and least expensive way to add a subwoofer to most sedans. Not having to construct a box is an advantage, but many vehicles will require a new rear deck panel and/or vent to be constructed to accomodate even smaller woofers. These custom vents and panels could cost as much or more than a prefabricated or custom box.
infinitebafr.gif Infinite baffle set-ups require a woofer with a beefier suspension for high power handling and one with better cone damping. This set-up will be less efficient in reproducing the lowest frequencies as compared to other second order or higher enclosures.
In any free air application, the back seat and surrounding panels should be removed to seal any possible areas where energy could be lost. It is crucial to separate (seal) the back wave of the loudspeaker (woofer) from the front wave of the loudspeaker. If not, bass cancellation will occur. This is also a good time to rid and deaden the trunk and surrounding areas of any unwanted noises and rattles.
I feel stupid I didn't realize this was posted in the home theater section. Sorry.
DEH80-PRS
XS Power d3400
This is posted in the home-theater section so I don't have a trunk... Which I now see you noticed
An open baffle doesn't always eliminate rear wave formations.
  • Who's Online   0 Members, 0 Anonymous, 629 Guests (See full list)
