Electricians - get in here wtf is this?
I dont think any of those plugs listed above match your outlet. But the outlet it self is either an old school refrigerator or a/c outlet. You should be able to remove the outlet and wire up an outlet you need.
truthsayer
Ground should be the L shaped prong. Is this in your house? Weird that a 3 phase outlet would be in a house
Normally that style is low voltage. 360. If the L points in then it would be 480 but who knows on this.
3-phase
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I bet there a bypass switch up close to the breaker panel . With out it it would fry anyone working on the lines to restore power outages or what ever lol. Unless this powers a stand alone leg somewhere thru the house not connected to the main power .
Got it figured out. It was the one ChevyBoy posted
Thanks guys :)
