Box Rise
Daddy_
Just have a question. Say I get 2 12" and put it in a ported enclosure. What will be the box rise at the final ohm load of 0.5, 1, and 2 ohms? Is it the lower you wire your subs the more box rise you will get or will they be all around the same rise? Could give you give me a rough number of how much.
Also those constant power amps that do the same amount of power at all ohms load they do not see box rise right?
Car: 2012 Acura TL Elite
Head Unit: JL Audio Fix86
Front Stage : Alpine SPX-17PRO
Rear Stage : Alpine SPR-60C
Component Amp : JL Audio HD 600/4
Sub : 1 12" JL Audio W7
Sub Amp : JL Audio HD 1200
Many many factors, of which no one can "calculate".
No.
This could be off as well, but, a guess, you can multiply your nominal load by 2-3. But everything, even a different song comes into play.
They don't do the "same power at ALL loads".
No.
Like I was talking about the JL Slash, HD, and the RF BDCP amps
Most JL amps are regulated so that they put out relatively the same power across a range of loads
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
I believe the JLs do the same power from 1.5 - 4. No matter what.
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
So will that amp have box rise?
The amp will not have box rise, no. The subs impedance will be altered due to box rise. If you wire your subs down to 1 ohm, and it rises to 2, you will still see 1000 watts. But also there's no specific way to tell how much box rise you will have. It all depends on subs, box, what car it's in, and you'll have to put a digital multi meter on it and find out for yourself.
Alt - Singer 330A
box rise all depends on the box. but theres not much you can do about it. you can have the exact same setup, have say .75 of rise, then swap boxs, and then have maybe a .96 rise. it varies.
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
Its not called box rise. It's impedance rise you're referring to. No way to estimate either. Like Kyle said, too many factors to consider. Cabin gain, enclosure efficiency, orientation of enclosure in vehicle, efficiency of amp, health of electrical system etc.
If you're worried about box rise, get some your downs and strap that bitch down to the floor.
If someone were to be able to figure out impedance rise, there would be no need to build different enclosures and text and tweak, tune and tweak. If it were able to be done on paper, people would design one enclosure perfectly to do everything that wanted to, but it can't be done on paper.
  • Who's Online   1 Member, 0 Anonymous, 1062 Guests (See full list)
