WhatsAminiTruck Posted November 26, 2013 Author Report Share Posted November 26, 2013 Ehhh, 600 cold crank amps? I don't remember the exact voltage... But it passed the charging system test Quote Current: Two SA-6.5s and two tweets in each door powered by an LA-4200, 240amp Mechman Alt, Two Memphis PR12s powered by an SAZ-1500.Waiting on my box to hook up my two SA-12s <3 Link to comment Share on other sites More sharing options...
n8ball2013 Posted November 26, 2013 Report Share Posted November 26, 2013 Thats not what hes asking. Hes asking resting voltage. Voltage is measured in volts. A 12 volt battery should float no lower than 12.6 volts and ideal is 12.8. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
WhatsAminiTruck Posted November 26, 2013 Author Report Share Posted November 26, 2013 (edited) I said I didn't remember the exact voltage, but if it was lower than that it wouldn't pass that as in whatever it should be at Edited November 26, 2013 by WhatsAminiTruck Quote Current: Two SA-6.5s and two tweets in each door powered by an LA-4200, 240amp Mechman Alt, Two Memphis PR12s powered by an SAZ-1500.Waiting on my box to hook up my two SA-12s <3 Link to comment Share on other sites More sharing options...
n8ball2013 Posted November 26, 2013 Report Share Posted November 26, 2013 So in other words you have no idea and yes it would still pass as long as a cell isnt bad or sulfation wasnt too bad. Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
WhatsAminiTruck Posted November 26, 2013 Author Report Share Posted November 26, 2013 As stated earlier. When I get off work I'll look at the little receipt thing for the volts Quote Current: Two SA-6.5s and two tweets in each door powered by an LA-4200, 240amp Mechman Alt, Two Memphis PR12s powered by an SAZ-1500.Waiting on my box to hook up my two SA-12s <3 Link to comment Share on other sites More sharing options...
Tarball Posted November 26, 2013 Report Share Posted November 26, 2013 (edited) breathe...everything is going to be alright... Edited November 26, 2013 by Tarball Quote CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
WhatsAminiTruck Posted November 26, 2013 Author Report Share Posted November 26, 2013 Lol I hope so! Quote Current: Two SA-6.5s and two tweets in each door powered by an LA-4200, 240amp Mechman Alt, Two Memphis PR12s powered by an SAZ-1500.Waiting on my box to hook up my two SA-12s <3 Link to comment Share on other sites More sharing options...
WhatsAminiTruck Posted November 27, 2013 Author Report Share Posted November 27, 2013 (edited) Have you checked the battery resting voltage? What kind of battery are you using? Thats not what hes asking. Hes asking resting voltage. Voltage is measured in volts. A 12 volt battery should float no lower than 12.6 volts and ideal is 12.8. 12.95 volts Edited November 27, 2013 by WhatsAminiTruck Quote Current: Two SA-6.5s and two tweets in each door powered by an LA-4200, 240amp Mechman Alt, Two Memphis PR12s powered by an SAZ-1500.Waiting on my box to hook up my two SA-12s <3 Link to comment Share on other sites More sharing options...
n8ball2013 Posted November 27, 2013 Report Share Posted November 27, 2013 Thats weird that your stock cheap duralast battery will rest that high. To be honest its hard to swallow that number. How tight is your belt? It can be too tight as well. I hate dodges. This is part of the reason why. I dont think a 96 would be pcm controlled or anything like that though Quote THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
hdorre Posted November 27, 2013 Report Share Posted November 27, 2013 The reason that the Duralast can be "resting" that high is because the OP probably drove to like Autozone/Advance/O'Reilly's/NAPA/etc with the battery installed, went inside to get his battery tested, and they probably tested it right there on the spot. Quote On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread Link to comment Share on other sites More sharing options...
