Mechman Alternators
Ehhh, 600 cold crank amps? I don't remember the exact voltage... But it passed the charging system test
Current: Two SA-6.5s and two tweets in each door powered by an LA-4200, 240amp Mechman Alt, Two Memphis PR12s powered by an SAZ-1500.Waiting on my box to hook up my two SA-12s <3
Thats not what hes asking. Hes asking resting voltage. Voltage is measured in volts. A 12 volt battery should float no lower than 12.6 volts and ideal is 12.8.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I said I didn't remember the exact voltage, but if it was lower than that it wouldn't pass
that as in whatever it should be at
Edited by WhatsAminiTruck
So in other words you have no idea and yes it would still pass as long as a cell isnt bad or sulfation wasnt too bad.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
As stated earlier. When I get off work I'll look at the little receipt thing for the volts
breathe...everything is going to be alright...
Edited by Tarball
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Have you checked the battery resting voltage? What kind of battery are you using?
12.95 volts
Thats weird that your stock cheap duralast battery will rest that high. To be honest its hard to swallow that number.
How tight is your belt? It can be too tight as well. I hate dodges. This is part of the reason why. I dont think a 96 would be pcm controlled or anything like that though
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
The reason that the Duralast can be "resting" that high is because the OP probably drove to like Autozone/Advance/O'Reilly's/NAPA/etc with the battery installed, went inside to get his battery tested, and they probably tested it right there on the spot.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
  • Who's Online   1 Member, 0 Anonymous, 1235 Guests (See full list)
