4th order blow-through in 2008 F-250
Holy fawkkkk your truck is sexy.. so is the rig its pulling.. damn
My setup,
Digital Designs M80
3 Re audio 10's ported tuned to 36 hz
Kenwood x-696
SHCA 0 gauge
Polk audio coax running off hu
Nice design and build.
05 Escape
2 Ascendant Audiio Mayhem 15s dual 1
Populus Audio 6500 (the only one around )
1/0 SHCA OFC
XS 3400 under the Hood
XS 3100s in the rear X2
Pioneer 80 Prs
Pac
Prv mids and highs
2 8s per door 1 tweet
Ok so I removed the box from the truck to do some of the shit I should have done before. I opened the top and was amazed at how easy it was, usually ideas like this one end in sawsalls and axes. seams like will be able to do that as frequently as needed. I then pulled a woofer to check for coil smell and to stuff the sealed side with poly fill. I was happy to find no smell so I took all woofers out and stuffed with poly. I sprayed the ported side with bedliner spray, re-installed the woofers and put the lid back on. I then Rapter sprayed the outside. I am impressed with the Rapter system, it's very simple but high quality. will put it back in tonight and see if the poly did anything.
5A8B8542-4E83-4E72-8CE0-874E388F2694_zps
e0646235-e1da-46ac-a35e-e8548a19a4db_zps
e6457289-e037-4b85-9369-86daea1ee08e_zps
BDC7994D-B7F2-4F9D-A99A-9973F16EF277_zps
360C767C-5061-4A42-8CF1-FC857B9FBE0F_zps
