Quick dumb noob question
bumpinTL364
Well, I'll make this as simple as possible: To run 2 500watt subs, should I buy a 1000watt amp and wire them in series, or get a 500watt amp and wire them in parallel? Is there really any difference (besides the obvious difference in impedance for different wiring setups)?? Thanks
masterbation is free, and even saves you money.sorry but someone had to say it
sorry, Jimmy...beat you to it (no pun intended)
LOLDON'T get a wife. Best advice I never got, and now it's too late <_<
My build: 12" DCON in a dorm room.
New/current build: 8" woofer, custom amplifier block, fiberglassed speaker pods
Buy two dua 4 ohm woofers
Get a 1000 watt mono smp
All the pluses together all the negative tigether
Run them to amp
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
You need to know the specifics of the amps. What is the impedance they are rated for? (4,2,1, .5 ohms). Also the impedance of the subs and if they have dual voice coils?
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Mids/Highs: Alpine SPR-50c 5.25" components
Mids rear: Alpine SPR-69 6x9
Mids amp: Alpine MRX-F65
Power/Ground: Massive Audio 4 AWG
Signal Cable: Massive Audio 14 Gauge
RCA's: Monster cable
Subs: 2 Rockford Fosgate HX2 12's
Sub amp: Crescendo BC2000D
Custom box - Herculiner with Silver port
Big 3 and power/ground - Sky High Car Audio 1/0 OFC
Coming soon:
H.O Alternator Singer or Mechman
Also what n8ball said. I have 2 dual 4ohm subs wired to 1 ohm on a 1 ohm stable amp.
Hu: Alpine CDE-141
Eq: Clarion EQS-746
Coming soon:
So n8, what you're saying is that running in parallel means I should buy an amp with double to power. Impedence really wasn't the issue here, obviously I'd run something so that if I had to wire in parallel I'd get 4ohm woofers and 1 or 2 ohm woofers to run in series...thanks guys!
As n8 said. Look at your subs ohms and see what your options of wiring are. From there add the rms of the subs together so 500+500=1000. Now that you have done that and know what your options for ohm loads are pick a amp that will do 1000w rms at the ohm you can run at. For example if you have 2 dual 2ohm subs you can wire at .5ohms(don't recommend doing) or 2ohms(best choice.) so you would need to find a amp that puts out 1k at 2ohms. Same if you had dual 4ohm subs you would need a amp that puts out 1k at 1ohm.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
It would help if you post the model numbers of the equipment you are looking at getting if possible.
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
Ok guys, like I said I'm not sure about equipment yet, but I'm looking at SA-12s, VVXv2s, IVXv2s, and anything you guys could suggest that would fit into about 4.5 cubes and run me around $150-$200, and then whatever amp would be able to power them handily
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
