Going Sealed or Staying Ported
Parker Smith
I drive a 2002 F150 Supercrew and as far as space for subs go, I have just about the worst vehicle possible. My first setup was a single 10 inch Memphis PR in a ported box under the seat. A few months ago I had a ported console box made and an Alpine Type R 10D4 installed. Due to my space restrictions, the port is too small and I was experiencing port compression. To try and remedy this, I lined the walls if my box with polyfill. I expressed my experience in another thread.
Here's my question: The shop I get my work done at said they would swap out my Type R for the slightly more expensive Phoenix Gold TI2 to see if it will react better to my box. With black Friday coming up, I am considering buying a 2nd TI2 and going sealed due to, once again my space restrictions.
Would I gain anything by doing this? I will be using my RF 1200 at 1 ohm to power them.
P.S. Not trying to make this a VS. thread. Just want to know which setup I would benefit more from overall.
Are you going for a SPL set up or SQ or both?
truthsayer
You may want to consider dropping down to a smaller driver if you have a severe limit of available space. A 10 or 12 is not going to sound good in not enough space.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
If keeping the same enclosure you need either less cone area or less xmax.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Take out the rear seat and you can pretty much do what you desire. If your concerned about seating, make a custom box that you can still connect the back of the seats to. I've seen it done once, looked good and wasnt bad to sit on either. Just make sure to add a little padding.
truthsayer
I don't want my setup to sound sloppy but I really want more SPL than what I currently have. I was hoping that by going to double the cone area and not able to have the proper port size, along with being able to achieve the proper size for a sealed box that I might gain a little SQ and SPL.
A high performance 8" subwoofer would give you more SPL than a 10" since the 8" requires less port area than the 10.
2010 GMC Sierra SLE Texas Edition Sky High 2/0 OFC Wiring
2 Digital Designs 1508's Supercharged
Digital Designs Door Speakers
Rockford Fosgate T1500-1bdcp
Rockford Fosgate Prime 300x4
Rockford Fosgate 3Sixty.3
SMD VM-1
XS Power D3400
Also have to consider if you can fit the the length of the new port within the restraints. Designing an enclosure for an 8" driver the low net volume calls for long lengths for low tuning.
That is my current box.
So you guys don't think that going to the 2 10's sealed would benefit me any?
I might could get my shop to trade my Type R for a Hertz 8 inch woofer instead of the PG if that really is the only good option I have without seat removal
Yeah, I ran 2 Sealed Pioneer 10's and output was not what I wanted. Changed to 2 Digital Designs 1508's ported and I'm very impressed.
SMD VM-1
XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 6292 Guests (See full list)
