Regular Cab truck Box
Single might be enough, but i believe 2 would put it into a high output box. not sure, someone else will have to chime in. Precission Ports are good to and they have a calculator website to help you with tuning lenths as well as numbers of ports your using.
How would I make PVC ports?
Lowe's sells raw PVC pipe, you just cut it to the desired length:
http://www.lowes.com/pd_87669-1814-PVC+07300++0600_?productId=3135451&site=shopLocal&utm_campaign=bazaarvoice&utm_medium=SearchVoice&utm_source=RatingsAndReviews&utm_content=Default
In the example I left you above 3 20" parts, you would just need to cut the above item in 3 identically sized parts.
You can still flare PVC pipe.
http://www.subwoofer-builder.com/flares-25mm.htm
You cut out some MDF circles and then use bondo to make the radius.
You then use a heat gun to heat the PVC then you can mold it down.
Just make sure you sand it smooth.
You can also do as CleanSierra and use a roundover bit on the MDF where the PVC will meet the MDF and then use body filler to smooth it out.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
The link didn't work but don't i need to flare the ends?
Here is a shot of the page:
Yes some flaring is definitely beneficial (not strictly necessary in every case), there are many ways to do some flaring by heating up the PVC pipe to a mold, you can get flares separately or you can round a bit the external edge of the hole where you are placing the flare.
Buying flares separately can be difficult since they must fit the pipe and not have an external diameter so large that won't fit properly in the side of the box.
Yes you should flare on the inside as well, try to get it as close to the same as the outer flare.
For speeds below 70% of the core limit of your port, the radius of the inside flare can be 15 - 20% smaller than that of the outside flare
  • Who's Online   0 Members, 0 Anonymous, 1083 Guests (See full list)
