*sticky* Free Tech support
I got a question, I am using a Rane RPM 26z for my processing and I need the optical toslink output from my 9861 to be converted into the digital AES input on the Rane. I have seen little boxes from M-audio and Hosa that do the conversion...but it would require me to get those little boxes converted to run on 12v as well. Any ideas?
Too Much Stuff to list .
First of all, Ray this is awesome of you to have offered this for so long. My question, is body filler strong enough to fill in a small gap between two panels in my box. I am currently building and bracing the box as I go. One of my vertical braces ended up being a tad too tall causing the box to be a little off square on the back. I didn't realize it a problem until I attached the side and saw the gap. I can't go back and take the brace out because it has been fiberglassed in.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
But there's no fun in coming up with a mackie vlz16 and going out the rca outs... I would really like to do like 1/4" inupts in either door for wither of the guitarists and then one in the center for the bassist... but for vocals and micing the drums, yeah i see no other way than a mixer for that! hmmm......
mixer is the only right way bro.
Got a quickie. Quick question that is. Im currently into a build in my 02 ranger edge supercab. Cant decide whether to upward fire my BTL 12's or forward fire them. I like the upward firing seeing as its louder but love the punch in your back of the forward firing. The upward firing you also dont feel quite as much in your seat as you would forward firing and upward is harder on the back window. Need thoughts or opinions on which direction to fire the woofers and the ports.
I like upfire. subs up port up
I usally tune 3hz higher than normal when doing this
This is why you should have used a bit1.
toslink in
But other than that, I dont see away around swapping the power supply to run 12v.
Could use a noisy inverter
no prob bro.
Ummmmm I would just glass over the gap, you can shove kitty hair in there first too.
then sand smooth
no prob bro.
then sand smooth
Ok thanks bro.
The optimal is 32 hz for the BTL 12 so you would recommend 35 hz tuning?
yep.
2.25-2.5 after with 45sqin of vent tuned to 34.5-35
