*sticky* Free Tech support
First thing about trobleshooting noise is figuring out what kind of noise you have.
Is it
Ground loop
Induced
Or system noise.
So
Unplug the input from your amp ...
Noise gone?
Unplug rcas just from the deck.. Noise gone?
And then plug an ipod straight into the amp.
No noise?
What you want deaf?
Is it
Ground loop
Induced
Or system noise.
So
Noise gone?
When I unplug RCA's from deck noise is gone. I tried grounded all the rca's by doing the wire around the outside of the rca and grounding it with no luck.
I have not tried unplugging from the input on the amp yet
Also I tried three different decks
RFX9400
RFX9320
RFX9420
Try unplugging the antenna
Ok ill try that tomorrow. and I would have never thought about that.
I let you know when i test more.. thank you
Basically ray, I have with rough measurements 21-24 cf (depending how I build my wall) in the back of my 4 dr 98 civic. I was wanting to do 4 15s, but I'm worried I don't have the sufficient space for them after displacement. Was gonna do 4 lvl 5s, but considering mayhems or btls as well. I was also considering a 4th order wall/clamshell design. I just don't want to put 4 in there and choke them out. I probably have the space for them, but then I see people like dbdon with his 15s in like 26 cubes. Would like 3 15s be better than 4 if I could get them in a larger more efficient box? Was gonna buy a design from you but didn't know if this q&a was included in the price. :pardon:
If i had 21cuft.
I might consider 3 18's
Flat wall.
Size, depends on what sub you use.
Bout 18 plus port and subs
Or so
