*sticky* Free Tech support
Ray, can you help me to find a 6x9" hole saw?
:rofl:
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
ive got two tony want me to send you one? pony express ok?
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
For you tony... Anything you need buddy.
As for turn on. Typically you can run three amps on a 200ma turn on before you need a relay.
If your voltage dips alot then you prob need a relay
As for usb tuning. If thats your main source then put the tone on a flash drive and tune with that.
I use -10 for 40hz and -5 for 1k
Hell ill trade you for a used muffler bearing.
Been needing 1 for awhile now
Any tips on building inside a trunk?
Also any tips on how to make a trunk look "pretty" if all of the OEM carpet and stuff has been removed, as it stands now it's just all Audio Technix visible
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
Look at some installs at my site
Aifresno.com
If Im going to be running an Aq2200, with 2 in wire ANL fuses in 0 gauge wiring what size should the 2 fuses be? AQ website says "External Fuse Rating 200 Amps"
you wnat to make it look pretty get lots of cardboard and start mocking it out. transfer the mock out to wood or you can fiberglass it.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
100 amp each fuse
Alright thanks ray :D Now i got to find a -10 at 40 hz
Ray i have a -8.8db 40hz tone will this work???
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
