*sticky* Free Tech support
Look at some installs at my site
Aifresno.com
I'm on it right now!
you wnat to make it look pretty get lots of cardboard and start mocking it out. transfer the mock out to wood or you can fiberglass it.
That's what I was thinking.
Do you guys think a router would be necessary or does it just make it easier?
Also Should I build the around the wheel well or just make a sort of square?
Don't know if I'm explaining myself right.
Current Build:
1999 Tahoe #ComingSoon
Previous Build(s):
Crossfire Magnum
5k Pontiac G6 GT
thats all up to you. router makes it easier not necessary though. Im not a fan of it because i tned to screw up with it. but it does work wonders
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
ray have you ever worked on the mitsubishi eclipse model 00-05? do you think you will be able to fit a proper ported box for 2 12s in there? just wondering. :drinks:
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
Its tight.
I did just do one with a jl w6-12 v3 on 500 rms
Metered at 47@39
And broke the windshield.
I can tell you that the rear view needs to be removed. Its what breaks those windshields.
So. Can you fit 2-12's.
Uhhh would be a smaller sized box for sure.
I dont think id do it.
Id rather run z beefier sub and more power to it.
Its the cheaper route to go anyway.
And yes... I said a jl w6 on 500 broke the muh fuggin windshield.
I was shocked too.
Its tight.
Metered at 47@39
I was shocked too.
Alright Thanks man. Changed my plans totally now im getting an XL 12 on 2k. And i will remove the rearview so i dont blow my windshield.
Sounds good to me.
Go 2500 and make sure to have plenty of battery. The stock charging system sucks nutz
Sounds good to me.
2500.. I was considering the crescendo 2k or the AQ2200 at 1 ohm? and a back batt and the biggest batt up front. also the Big 3
Ok. What ever you like.
Im just a power whore
Well you couldnt recieve pms :pardon:
So does the eclipse flex the windshield a hell of alot compared to other cars??
And what kind of box do you suggest for a single 12 xl for an eclipse. Sub back port back? maybe?
Windshield moves alot.
You wanna go up and up cause the hatch door will close off alot of the sound if i remember right.
Ill see if i can find the box i built for it.
Might take a couple days
