*sticky* Free Tech support
Ray, never got an input from you, your opinion is very important for me, you think those specs are good? would you do anything different?
Dmm set to ac volts
Play a 50hz tone for sub and 1k for highs
0db track
Fecoupe.
Your post involves some thought.
I havent forgot about you.
Dmm set to ac volts
0db track
Fecoupe.
cool mate, thanks a lot, you know i ain´t asking you about details, design or anything because you are a very busy guy, and i actually like designing and building myself without any help, but i would definitely need an input from a guy like you just to check if my plans are good since i´m a total noob when it come to walls, i´m not in a rush or anything, take your time and whenever you can think about it just let me know, cheers mate!! :drinks:
Would you be willing to design a box for me? If not, do you know anybody that could help me?
This is my first system/box build and I wanna make sure I build the box right so it doesn't sound like garbage.
If your interested the biggest I could fit in my trunk is 30x15x20 (L)x(W)x(H)
The box will be for 1 Fi X12
Fs: 35.6 Hz | 35.8 Hz
Re: 1.9 Ohms/coil | 2.9 Ohms/coil
Qms: 5.58 | 5.55
Qes: .47 | .47
Qts: .44 | .44
Mms: 127.9g | 126.1g
Cms: 1.6mm/N | 1.6mm/N
Sd: 481cm^2 | 481cm^2
Vas: 50.7 l | 50.7 l
Spl: 88.7dB 1W/1m | 88.8dB 1W/1m
Bl: 10.8 N/A | 13.2 N/A
Xmax: 18mm | 18mm
Rms: 400W * | 400W *
Sealed box: .6-1.1 cuft | .6-1.1 cuft
Ported box: 1.6-2.2cuft | 1.6-2.2cuft
Sub OD: 12.500” | 12.500”
Cut ID: 11.125” | 11.125”
Mounting depth: 6.250” | 6.250”
Displacement: 0.08cuft | 0.08cuft
Fi X12
AQ750
Pioneer DEH-6300B h/u
Hey i was wondering if anybody would be able to help me out.
i have a 2000 kia sephia
automatic tranny, manual windows, manual locks, panasonic head unit.
i was wondering if any of you guys had any idea of where to find a hole in the firewall for my 8 gauge power wire to run to my amplifier.
help would be gladly appreciated!!
Right where the clutch slave cylinder would go if the car was a manual trans.
You will need to drill a small hole but it will be clear
would i be able to go to an Auto parts store to have this done?
i don't know where the slave cylinder would be located. sorry.
Look to the left of where the brake pedal rod goes through. From the inside.
You will see a perforation in the padding on the firewall.
