*sticky* Free Tech support
What type of box do you recommend for a Alpine type R 12, in an 05 mustang?
Like port back sub back? I want it loud in low, Not a SQ car. Probably want it loud in the 30-50 hz range... listen to alot of rap. So what do i tune to? preffered amount of port per square inch and total. and what tuning. what type of box
Another thing. When im designing a box. For say i want a box loud for the lows probably around 30-50 and not so much upper range.. Would i give the box more port per sq inch than usual?
On my lvl 13 box i have 15 per at 34 hz.
Thanks ray means alot
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
So i would like to know about how long this battery (Kinetix HC600) would last in a power wheels that will have a H/U, with a set of 6.5 components, set of 4.5 4 ways, 2 8" woofers. I want the power wheels to be fully operational so that you could drive it. I would also like to know if i put a small amp, maybe 200wrms, how long would this battery last? Any ideas or could lead me in the right direction.
I bought this last week http://www.sonicelectronix.com/item_22417_Pioneer-AVH-P3200BT.html For a 05 mustang standard not the shaker system. So what do i need to do with parking brake wire. I dont have the unit yet so. Could i ground it or do i have to connect it to the actual parking brake wire? (what color is the parking brake wire?) and i connect the speaker wires and thats it for installing that unit or is there more?
Thanks ray in advance :D
Speaker wires are normal.
As for p brake
Need a relay
Lt green goes to pin 30
Pin 85 & 87 go to ground
Pin 86 goes to rem turn on off the deck.
Thats it
As for p brake
Need a relay
Thats it
Is the relay for the bypass where it doesnt have to be in park to view videos and navi? So you basically just explained how to bypass it with a relay?
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=075-140
Whats the big metal thing at the top? the 4 small ones are pins where does the big pin at top go? power?
Thats just the mounting tab.
I just saw that.
Was a strange issue.
Constant was touching ign behind the radio.
This causes no start because the deck constant shares the power feed with the ecu
Same fuse under the hood.
Its a 7.5amp
Is this for me?
So what you just explained is a bypass where you can view DVDs without being in park?
and im assuming you connect the pins with this http://www.darvex.com/store/pc/18-22-Gauge-Vinyl-Female-Disconnects-25p299.htm ?????????
and the mounting pin is untouched
Yes those connectors winn.
And yes itz for video in motion.
And yes 4x4 blazer. Thats for you
I got my head unit today and i have some wires and i don't know what they are or where they go.
The First one is a purple and white wire on the head unit harness. it says "reverse gear signal input" what do i do with this???
Next.An yellow and black wire on the head unit harness. It says mute on it. Do i connect it to the other harness mute which is brown? What do i do with that?
And hopefully last, Is a Orange and white wire. It says nothing on it. Its on the head unit harness So i have no idea what to do with it or where it goess. BUT on my aftermarket harness is a Orange and white wire that is the illumination dimmer.. Do i connect these two? Because there is also a Orange and black wire in the after makret harness that is the illumination ground what do i do with that? Also there is just an orange wire on the aftermarket harness
