*sticky* Free Tech support
Hi Ray,
Just one question that I just need a clear cut answer too because so far everyone around me has given me 100 different answers. I just got this digital volt meter and I would simply like to make sure that while my system is playing I can monitor my voltage so I know I am not dropping to low and that I stay above 13.8v so where exactly do I attach the wire so that voltage is accurately read. I have already mounted and grounded the meter just need to figure out where to connect the other wire so voltage is read properly. BTW I drive a 2005 Honda Civic LX if that info is needed. Thanks in advance!
*Edit* I had it connected to the 12v source that I use for my amp turn ons and accessories but I noticed it constantly fluctuated (never dropped below 13.6) but I always figured it should remain steady. Someone told me it was suppose to do that but it didn't make any sense to me.
2013 Dodge Charger
Build Log
1996 Ford Explorer XLT 5.0
Build Log
2005 Honda Civic LX Coupe
Build Log
SMD SUPER SELLER!!!!
My Selling Feedback
Connect the lead to the power connection right at your amplifier. In with the 4awg or what ever size power wire you have.
Then calibrate the volt meter with a dmm. To make sure its correct.
Yes winn..
Thats it
Yes winn..
Thats it
Ray, will I have any problem running 2 cooling fans and 2 amp remotes all off the same relay?
1998 SS/T Ram Build Log
- Kenwood KVT-514 and KNA-G510 Navigation
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- Second Skin Dampy Pro
- XS D6500
If we are talking computer style case fans
No problem.
A standard "bosch" style relay will support 30amps continuous.
Ray,
I have severe motor noise coming from my tweeter when I rev my engine and just an annoying hum while at idle. I have tried grounding my RCAs to the headunit without luck. What else could I do that may get rid of this? I am running my 4 channel RCAS to a Kicker KX3 and then running the front channel with a 20x crossover to 1 side of 1 of my 175.4s. I am splitting the other rear channel 3 times with a standard crossover to the other 3 sets on the 2 175.4s but do not get any noise through the mids in the doors.
Can you help?
Thanks
Cody
No problem.
Cool thanks man......hey I'm sending you a PM!
- 2 DC Level 3 12"
- Components???
- Sundown ???
- Sundown???
- Knu Konceptz
- XS D6500
