*sticky* Free Tech support
Im not confused at all.
Ray cannot be confused. he is inhuman.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I am not using regular crossovers, I am running just the kicker KX3. Could this still be the problem?
I'm no expert but i ve had very similar probelms to you cj, try moving the rcas away from the amp, or just move each rca until you find the one introducing the noise.... that's what happened to me when my rca was laying over a ground for my 4 channels
Just an idea....
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
id guess its the xover
Quick question on my head unit on the bottom there is a AUX input its 2.5 mm jack I got a converter from 2.5 to 3.5 hooked it up and tried to play a song with it. You can hear the background music but cant hear any of the words and all. Think this is because the converter part was really cheap?
Head unit model is deh-6800mp
Big Wheels Are Like G-Strings...Anyone can put them on but it don't mean they look good.....
Uhhhh.
All pioneer aux jacks are 3.5mm
Sounds like your using the w/r input.
Wired remote
Uhhhh.
Wired remote
no its a 2.5 aux jack heres the copy and paste from the description
Front Panel Auxiliary Input:
This unit has a 2.5mm sub-mini jack auxiliary input located on the bottom edge of the motorized front panel. This AUX 1 input must be turned on in the Initial Settings menu before it can be selected as a source. Once AUX 1 is selected as a source, you can change the source display of the input to any 8 character name. A second auxiliary device can be connected to this unit when an optional adapter is connected to the IP-Bus connector on the rear panel. This auxiliary input (known as AUX 2) must also be turned on, and an 8-character name for the input can be stored in memory. See below for more information on the 2nd Auxiliary Input.
this is the adapter i bought think maybe because its not the higher end?
http://www.amazon.com/2-5mm-3-5mm-Female-Stereo-Adapter/dp/B001078FV8
Ray I think its the cord i got someone said it only working in mono so that would most likely be the cause right?
ill have to hit bset buy or radio shack
O yeah.
Bottom of the face
Yes, you prob have a mono cord.
