*sticky* Free Tech support
Is this a rule across the board or just in the electronic crossover world?
Is it "bad practice" to feed a passive crossover network with a signal that has been processed electronicaly?
Rolex you sicken me.
Just let me finish my pie
~ Juice
Rule in everything audio world.
Read up on cascading
Starting to look it up and get some info. But based on previous expriance it seems that the "bad practice" of doubling up has been around for years and continues to be used. How many systems do we see using whatever type of high pass electronic x-over feeding a passively crossed over component set. ( this is just one example.)
Thanks for the direction, I'll study up.
~ Juice
O yes.
A very common bad practice.
Not sayin i dont ever do it. Just that its considered bad practice.
I'm trying to get the slope a little steeper for a few sets of Boston Pro Series components ( the older ones with the Plexi window in teh x-over)
I'm running a a Fosgate EPX2 which has a 12db slope.
i've X'ed the sub over at 100 on the low.
Sent 100 and above to the rears ( 5.25" set)
and sent 250 and above to the fronts (4" set)
I'm hitting them all with 85 watts RMS and it seems they cant hang ( at least the rears) with playing that low with that wattage at that crossover frequency with that slope. If I bump up the x-over frequency to the rears I'll have a gap between 100Hz to whatever i Cross the rears over since I will not x-over my subs any higher than 100hz.
Any imput, besides getting some stouter mid bass drivers :)
BTW, the amps are not using their internal cross overs, thus the reason for the initial question.
Damn, I just realized then the speakers would be run by 3 x-overs in cascade
~ Juice
Just raise the freq.
Home theater system, 1 6.5" focal p.e buyout .5 cube enclosure. Port or not? I got two 1" pvc for 50hz.
Also dayton 10" SD270A-88. Now in 1.3 at 28.
Thinking of a 2.0ft at 26. Sound good?
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
When running subs over their rms wattage should i build the enclosure smaller to control the cone better? I think i have heard this before, I just wanted to ask your opinion. I can give more details if needed.
