Installing new head unit.. won't turn on
I know in gm cars that the yellow and red need to be connected together. That's my experience. Try that first. Bc I had the same issue when I installed in my grand am bc I didn't think I had to so when i tried that, it worked
Its fine to have constant power tied in to the existing harness You're going to need to take the red, switched, wire and go to the fuse box with it and a fuse tap. Find a fuse that goes hot when ignition is in on or accessory mode, and take your red wire to that fuse. Problem solved
He has the correct module he doesnt need to run a wire to the fuse box. The module is probably bad
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I agree, it sounds like the middle is definitely bad.I was just stating how to get him up and running. I should have suggested replacing the module. I've never run the bypass(the one that maintains factory fo door chimes right?)so I don't have the experience with them.
In certsin vehicles that chime box does more than just chime. It may be a necessity in my malibu it turns on lights like a christmas tree without it
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
what i mean is hook the acc wire from the hu into the red wire going into the module therefore bypassing the module part of the hu
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
And if the module is bad its still not providing its function. It does more than just provide an ignition source
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 873 Guests (See full list)
