My small build , "New Focal component set" Pg 89
Looks pretty sweet. I like the tweeter mounts that came with the set. Does the dash cover do anything to the acoustics up front? Nice stealthy front stage. I bet it sounds amazing, best you have built so far?
Make a vid when you get a chance.
Not sure if the dash mat works but it cant hurt. I like the looks of it.
Yes best I have built so far. Best sounding and after all the work its actually a simple set up.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
I went out today to play with the set up. First off I reset the gains. I found the head unit clips at 4k hz at volume 56 so I used that volume to set the gains. I set the sub at -5db 40hz, I set the mids at 0db 1khz and the tweets at 0db 4khz. I also set the gains then backed off the tweeters until the blue light on the amp went off and did the same for mids and sub.
I then set up the auto eq and auto time alignment. Back to that later.
Then I played some music and it sounded ok with the auto eq but I turned it off and started to play with the eq. I set the time alignment by measuring (always liked that better)  After all the F ing around I found that all I needed to do is turn off the auto EQ set the eq to flat, set the crossovers and slopes and I could get it all to sound real good just by that. I have the tweeters hpf at 2500hz -3db with a 12db slope. I have the mids hpf set at 4000hz and lpf set at 100hz with a 6db slope. The sub is set at 80hz with a 12db slope. The mids will play decent mid bass with out distortion. The tweeters don't have a harsh sound and the sub has a ton of headroom.
All is good and sounds great.
Tried to make a vid but my go pro needs to be charged.
80prs
DC 180 alt
Getting a big chunk for taxes.  I am looking at a couple of amplifiers. Please give me your honest opinions. Don't think about price ,,.just the amps and what I have. And yes one amp that can do it all is what I am looking at. Thanks
I am just not sure I would be able to tell a difference between the two amps and my Rockford fosgate p1000x5
My Rockford puts out 75 w x 4 @ 4 ohms and 500 W x1 @ 1 ohm for the sub. With the two amps listed I can run wire my sub to a 4 ohm load and the amps would put out just a bit more power to the sub. The other 4 channels put out twice the power. Do you think I would be over powering the Focals or just giving myself a lot more headroom and a much cleaner signal?
I would use channels 5-6 bridged for the sub and channels 1-4 for the mids and tweets on both amp options.
Arc Audio xdi 1200.6  Class D
4 Channels @ 4ohms (Ch 1-4) 150 Watts
4 Channels @ 2 ohms (Ch 1-4) 150 Watts
2 Channels @ 4 ohms (Ch 1-4 Bridged)   300 Watts
2 Channels @ 4 ohms (Ch 5-6) 150 Watts
2 Channels @ 2 ohms (Ch 5-6) 300 Watts
1 Channel @ 4 ohms (Ch 5-6 Bridged)
600 Watts
  • Imagine a single amp that can do everything you need in a most any car audio system. If that thought excites you then the XDi 1200.6 is the answer to all your car audio needs. With its elegant brushed aluminum extruded aluminum cosmetic case (XDi Level 2 cosmetics package) and affordable price point the XDi amplifier series is perfect for the daily driver or the wildest of custom installations.
    At 150 Watts by 6 channels at 4 ohms and a plethora of HP, LP, AP and BP crossovers the XDi 1200.6 is the perfect amplifier for most any type of system. Three Way active, or passive? 4 channels plus sub? 5 Channel operation for a full system? If you can think it this amp probably does it.
    Compact, elegant, and yet full of unmatchable power the XDi1200.6 multi-channel amplifier is small enough to fit just about anywhere in a vehicle allowing you that personalized "Big Sound" without the loss of valuable trunk space.
  • Multi-channel amplifier (Six channels)
  • Microprocessor Class-D design
  • Designed and Engineered by Robert Zeff
  • High frequency power supply design for improved signal transparency and overall sound quality
  • Remote Bass Boost Control (Included)
  • Extruded Aluminum CNC chassis design (Level 2 XDi Cosmetics)
  • Full range amplifier design
  • Single side connection design
  • Nickel Plated RCA Terminals
  • Quick Disconnect speaker terminal plugs.
  • Audiophile Class D output filter networks.
  • Detailed micro processor controlled protection
  • Large, High Frequency switching power supplies
  • RCA Inputs are compatible with speaker level inputs.
  • Fault Codes Storage of the last protection code detected
  • Hi Signal to Noise Ratio without compromising power output.
  • Fully Balanced Input Stage significantly increases flexibility
  • Ultra Low ESR, High capacity power supply storage capacitors
  • Flexible mounting orientation for vertical or horizontal installations.
  • Next generation high speed Class D technology powering all XDi amplifiers .
  • Bridged Mode Auto Detect Turn-on works with most chip based OEM Headunits.
  • Precision filtering isolates the power supply reducing unwanted interference in radio reception
  • Block type terminal connections
Arc Audio local price 779 + tax but hoping I can make a better deal in person.
I also like the Zapco Z-150.6 SP Class A/B local price is 1000 + tax
6-Channel Street Power competition amplifier
  • Wide range dual crossovers allowing band-pass filtering
  • Variable bass boost
  • Variable subsonic filter
  • Ducted Air fan cooling system
  • Space-age technology for cooler output devices
  • Proprietary gold panel mount RCA Connectors
  • Dash mount remote gain control available
Specifications
Power @ 4Ω: 6 x 165 watts
Power @ 2Ω: 6 x 275 watts
Power @ 4Ω Bridged: 3 x 550 watts
THD @ Rated Power  < 0.05%
Signal to Noise Ratio > 90dB
Channel separation > 60dB
Frequency Response 10Hz to 30,000Hz ±1dB
Input Sensitivity .25v to 8v
Dimensions in mm: 241(W) x 62(H) x 573(L) Overall: 241(W) x 62(H) x 614(L)
80prs
DC 180 alt
I would run a separate sub amp. Even separate mid amps right and left and separate tweeter amp too. That would be my idea of ultimate but maybe that's just me.
Pioneer 80PRS
So 2 two channel amps and 1 mono?
I will have to look into it.
80prs
DC 180 alt
Well what I was going to do: I bought 4 of the CT sounds at125.2 when they were on sale for $99 each. I plan on bridging one on each front mid (dual mono), one in stereo on the tweeters, and one in stereo on the rear fill. This sounds like overkill but it will allow me to run with the gains set all the way down and leave lots of headroom. At least that's the plan if I can find a place to put all the amps. Lol
Pioneer 80PRS
My limiting factor is space
80prs
DC 180 alt
Yeah I will probably end up stacking mine.
Pioneer 80PRS
The ARC amp has a better price point but is a class D amp where the Zapco is Class A/B. Either would be a great choice, a doubt you will notice any sub stage change but your mids & Highs could be cleaner and louder possible. Just depends on want you want to spend to improve your system with minimal gains.
Stick with the 5 & 6 channel amps for your space requirements and ease of set up. Would you need a DD-1 to set gains of new amps?
  • Who's Online   0 Members, 0 Anonymous, 1117 Guests (See full list)
