oldsoundguy Posted January 2, 2017 Author Report Posted January 2, 2017 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
oldsoundguy Posted January 3, 2017 Author Report Posted January 3, 2017 Well after going back and forth with Soundqubed I decided to give it one more shot. I came home and mounted the sub inverted just so I could hear anything weird from the motor. I noticed that the leads on one side of the sub didn't have any Zip ties on them so I thought that might be it. I put a couple small zip ties on just like the other side and inverted the sub. It was making the same noise coming out of the port. I then put the DC sub back in and inverted it. It sounds amazing. So I told Soundqubed I was done with this 8 inch sub and what did they want me to do. I did send them the vid of the noise. We will see what they do. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
oldsoundguy Posted January 3, 2017 Author Report Posted January 3, 2017 Well UPS came with a bunch of stuff for me. Also here is a pic of the DC sub inverted. Looks real cool IMO 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
oldsoundguy Posted January 4, 2017 Author Report Posted January 4, 2017 I will end up putting the sub back in the normal way. Just wanted to see what it would look like. It looks like something someone would want to steal. That is the biggest reason its going back in the box. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
oldsoundguy Posted January 4, 2017 Author Report Posted January 4, 2017 Looks like I have the day off tomorrow. Seeing that I had a bunch of stuff show up today it seems like the perfect time to install some of it. I will take some pics and a vid tomorrow during the install. I am hoping to be able to get the CT sounds 5.25 set in this weekend if all goes well. The adapters should be here Friday so that gives me the weekend to figure it out. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
reedal Posted January 4, 2017 Report Posted January 4, 2017 Just a thought for the new soundqubed sub. You said you made a spacer ring for it. Is it possible that the new sub is fine, but the spacer ring is causing the noise you hear? Screwing it into place may not seal it/hold it as tight as needed. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
bcbrassard Posted January 4, 2017 Report Posted January 4, 2017 Damn man, what a hassle with the SQ subs. Soon as i can afford it i am ditching mine for something way better. Thats a healthy pile of electrical upgrades. That should definitely help! Looks good, can't wait to see what you do with the CT 5.25.
oldsoundguy Posted January 4, 2017 Author Report Posted January 4, 2017 8 hours ago, reedal said: Just a thought for the new soundqubed sub. You said you made a spacer ring for it. Is it possible that the new sub is fine, but the spacer ring is causing the noise you hear? Screwing it into place may not seal it/hold it as tight as needed. I had it all screwed down and it still sounded like that. I also inverted the sub without the ring screwed it down and again still made the noise. But I am not ruling out install. I have made plenty of mistakes in the past. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
reedal Posted January 4, 2017 Report Posted January 4, 2017 Ok, that's good, it was just a thought I had. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
oldsoundguy Posted January 4, 2017 Author Report Posted January 4, 2017 I am not done with the Soundqubed sub. I will do some more testing. I want to go out right now and do it but its cold as F out side right now. I have also been sick for a couple weeks and being outside in the cold doesn't help. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
