Need help with the watts and ohms.
I have a question regarding how wattage is distributed between speakers. I understand that my amp, will supply 3000 watts at 2 Ohm bridged. And if I have two drivers 4 Ohm each connected in parallel, I will drop the Ohms to 2 in total. So my question is, If I have these connected to my amp in the said configuration, Will EACH driver get 3000 watts? or is the power evenly distributed say 1500 watts per driver?
Thanks.
Louder is BETTER
simple answer is that your power will be distributed.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
power is distributed evenly. your amp can only push 3000 watts if it is a good true rated amp. and each speaker will share that power. 1500 a piece
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
The amp is rated at 3000W into a 2ohm load.
Both 4ohm speakers wired together result in a final 2ohm load.
The amp will only see that final load of 2ohms which should get the 3000W.
Since the final load of 2ohms is made up of two speakers, they will share the 3000W between them.
Also since both speakers are the same impedance (4ohms), they will share the 3000W evenly between them.
So in summary, each speaker will get 1500W.
NOTE: This is theoretical and there are MANY other factors that will affect the "true" power that the speakers get, but this covers the basics.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
  • 2 months later...
I know this is a bit old, but those who have already posted will benefit from this as well. I was building a custom fiberglass console for my F250 that housed 2 Kicker Comp 10s and posted the build on another site. I asked the question about wiring and found that the impedence and load depended on how I wired it as well as the components that were being used. I was referred to this site and it was right on the money http://www.bcae1.com/spkrmlti.htm. It broke down the differences between wiring in series and parallel and the differences of load respectively.
  • Who's Online   1 Member, 0 Anonymous, 1051 Guests (See full list)
