cnet15 Posted December 4, 2013 Report Posted December 4, 2013 i currently have 2 subs running off of one rockford p1000x1bd. i plan on getting a 2nd amp and getting two ascendant audio havocs. my question is if i want to put these subs in one enclosure is it okay to have them running off of two separate amps? or will i have to have them in separate chambers?
OrzechNJ Posted December 4, 2013 Report Posted December 4, 2013 if u planning to use the same amps theres no problem at all to run two subs in the same enclosure.. you just have to match the gains on the amps.. or use one as a master and second as a slave if possible.. sometimes Loud is NOT pretty Sounds like its safe to go ahead and bend that ass over.
ZAPCO209 Posted December 4, 2013 Report Posted December 4, 2013 If u use a common chamber sub enclosure then u can gain match the amps using a dmm, there are many videos on youtube that show how to do this. THE DRIVING FORCE
cnet15 Posted December 4, 2013 Author Report Posted December 4, 2013 If u use a common chamber sub enclosure then u can gain match the amps using a dmm, there are many videos on youtube that show how to do this. alright i'll have to check it out.
cnet15 Posted December 4, 2013 Author Report Posted December 4, 2013 if u planning to use the same amps theres no problem at all to run two subs in the same enclosure.. you just have to match the gains on the amps.. or use one as a master and second as a slave if possible.. and yes ill be getting another p1000x1bd
