help! no output:(
Awhitewookie
Help! I just finished a 17 hour drive to Florida, (listened to music the whole time but hardly any bass) and I went to show a buddy my system and there is zero output from the subs. All the RCA's are good, using a PAC lc1, all speaker connections are good, amp is not in protect and is on without smell. I don't know what to do
MY BUILD
1998 Ford Explorer 2dr sport
1/0 Big 3 1/0 everything
Alpine cda-9884
Crescendo CZ components
(2) Crescendo bc2000's
(2) Jolt 150ah
(2) Yellow top optimas
(1) Juicebox black cherry addition
(1) Mechman 270 avbm
miss my bc5500 and (4) 15's
You know why people are ass holes online but not in person? Because getting punched in the mouth hurts.
Something is wrong with either the amp, the coils on the subs or the wiring and you'll need to check each one of those out separately to trouble shoot the problem.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
Use a DMM and check the output voltage of the pac lc1 using a test tone to see if your getting the correct output.
Test anything and everything from the h/u all the way back to the subs and make sure everything works as it should and supplying power or signal.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
I'll get back with results
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Amp is the problem. Took the back off and found some burnt stuff
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
Soooo Amp Medics just called and said they have had the amp playing perfectly for 2 hours. So much relief but so much confusion.
When diagnosing I put a new pac lc1- no change
New RCA's from HU to amp without a pac lc1- no change
Moved RCA's to the other preouts- no change
Fuses checked and had identicle voltage
Subs wiring was good and read .08
Only thing i didnt do was check RCA voltage because for the life of me couldnt figure it out. Even read threads and videos of how to and couldnt figure it out
MY BUILD
Alpine cda-9884
(2) Jolt 150ah
  • Who's Online   0 Members, 0 Anonymous, 671 Guests (See full list)
