Problem with new components
xDark Admiralx
SO i just installed a set of Rockford Fosgate T1675-s in my car and i am getting power to the tweeters, but i am not getting any sound from the speakers. I'm trying to find out what went wrong but from the looks of it, everything is hooked up properly. I think it may be a problem with the crossovers but i'm not sure.
Those inputs in the crossovers can be a bitch, make sure you have good WIRE connection in the terminals. Trust me they need to go in deep with no insulation on the crimps in the crossover its self.
Idk if the T1's have Bi-amping, but if they do, check inside of the the crossover and see if there is a switch that says "bi-Amp" and make sure it is turned off.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
T1s have bi-amping but most of the time they come with the switch off. You can look thru the window in the front of the crossover to see what position its in.
If your using a single amp then just use a jumper wire from the woofer to the tweeter so both have input going into them.
If the crossover has a switch to bi-amp or single amp then switch that to the single amp position or otherwise just use a jumper between the two inputs.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
  • Who's Online   0 Members, 0 Anonymous, 1463 Guests (See full list)
