how do I wire direct leads
I mean I have 2 holes for my positive and and negative but every screw from the diagram u drew shouldnt go through the box right? (4positive screws and 4 negative screws)
the reason why is you can adjust the ohm when needed without taking the subs out or do some testing for each sub here a real pickof someone build this is one dual coil sub
do this for every sub so if you have 2 subs their be 8holes for them then the 2 for going to the amp
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Ok So qucik question... So I will now need 22 ring connectors 8 for the inside... . And outside 6 for posiitive 6 for negative and 2 to run to amp ...14 for the outside right?
that sounds about right get 25 just in case I always like to get extra just because I always forget to add something and don't forget to buy the 8ga butt connector
2 sundown sd-2 d4
flex tech
box design by Joe X
A crimp or solder is fine... Both isn't necessary
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
What kind of nuts bolts and washers should I get to fit the 8 gauge lugs?
I found aluminum nuts and bolts at ACE Hardware and copper washers for mine.
80prs
Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier
Incriminator IA 10.1
Focal PS 130v 5.25 (doors)
4" Faital pro Neo (kick panels)
3" Faital pro Neo and focal tweets( dash)
DC Audio level 3 12"  custom box designed by joex built by me
AGM front, XS 750SE batteries rear
DC 180 alt
99 Toyota Tacoma extra cab
http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
  • Who's Online   1 Member, 0 Anonymous, 1527 Guests (See full list)
